My Analogue sensor trigger is not working in Cayenne
#21
also PM me your email_id
#22
char ssid = “”;
char wifiPassword = " ";
char username = " ";
char password = " ";
char clientID = " ";
int inPin = 5;
int vref = 3;
int Clm35 = 0;
int Press_bar = 0; //analog voltage reference ( 0- 3.3 volts ) sur le esp8266-E12 c’est 1 volt
int pressure;
pinMode(2, OUTPUT);
digitalWrite(2, LOW);
pinMode(5, INPUT_PULLUP); // pin input
pinMode(4, OUTPUT);
digitalWrite(4, LOW);
void loop(){
delay(1000);
CAYENNE_OUT(0)
int val = digitalRead(inPin); // read the input pin
delay(100);
Cayenne.virtualWrite(0 ,val);
CAYENNE_OUT(1)
float Press_bar = (((analogRead(A0)*10)/ 1023) - 0.5); // read adc input pin = 30mv/mbar
// la valeur 0.6 is correction of pressure
Cayenne.virtualWrite(1 ,Press_bar, “analog_sensor”, “null”);
CAYENNE_IN(6)
if (currentValue == 1)
//do whatever you want when you turn on the button on cayenne dashboard
digitalWrite(2, HIGH);
else
//do whatever you want when you turn off the button on cayenne dashboard
CAYENNE_IN(8)
digitalWrite(4, HIGH);
else
#24
i checked your account and there are 4 trigger out of which 3 are turned OFF and one which is ON has not run even once. so i guess you have not crossed the sensor set trigger value.
#25
I did cross the value many times but it is not triggering , I will send you screen shot of value above threshold value to trigger alarm
#26
the value is above threshold
#27
can you give it a try now?
#28
Other triggers are working fine , I intentionally turned off to check & verif this analogue trigger
Hope you got my point , ok sure
#29
Dear Now it worked
did you change any thing ?
#30
yup. i deleted the widget and re-added a new one. then added a new trigger for this widget.
#31
now that it is working you need to modify your code according to this post Sending MQTT messages within notification limit
#32
can you update this in my sketch and email me , it looks little confused
when you created new trigger - did you put the limits as before or any special settings , if i select analogue as unit then no reading appears
#33
the sketch from the topic is straight forward. you just need to make the changes required.
#34
OK Thanks Shramik , Great & enjoy Wish good day
