Send data from cayenne to arduino possible ?!
DEBUG: Attempting MQTT connection…failed, rc=-1 try again in 5 seconds
this is the message that gets me out of error, please can you be more exhaustive in describing the code?
are you using an esp or Arduino device? it is working without any issue on my nodemcu. the code is quite straight forward I guess. what is the thing you are not getting? it first connects to the wifi, next connect to the server. if connected, subscribes to the publishes topic of sender device.
nothing, I can’t as you say, I ask for help, keep giving me the same mistake
which part of the code do you want me to explain. (not the entire code)
I don’t know what the problem is and if it depends on the code, but I posted the error that gives me, so I think it’s an authentication problem
i just tried again the same above code with wemos D1 mini and it worked for me again. which device are you using?
i am using esp8266
can you provide a link to the device.
spiegati meglio. è un nodemcu 12e
it should work on nodemcu without any issue.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// ---------- DEFINE CONSTANT VALUES ----------
#define MQTT_SERVER “mqtt.mydevices.com
#define MQTT_SERVERPORT 1883
#define MQTT_USERNAME “”
#define MQTT_PASSWORD “”
#define CLIENT_ID “”
#define CLIENT_ID_SUB “”
#define MQTT_TOPIC_BTN_ONOFF “v1/” MQTT_USERNAME “/things/” CLIENT_ID_SUB “/data/2”
// ---------- INITIALIZE INSTANCES ----------
WiFiClient espClient; // Creates a client instance for the PubSubClient
PubSubClient client(espClient);
// ---------- DEFINE VARIABLES ----------
const char* ssid = “”; // WLAN-SSID (WiFi router)
const char* password = “”; // WLAN Password
// Define a datatype to store the mqtt message, up to 50 bytes.
char msg[50]; // 50 BYTES QUIZAS SEA MUCHO AL GAS, pero bueh
// -------------------- SETUP -------------------
// Initialize serial monitor for debugging purposes.
Serial.println("DEBUG: Entering setup ");
// Attempt to connect to WiFi.
WiFi.begin(ssid, password);
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println(""); // Faltaria agregar que muestre el ip si no es estatico
Serial.println(“WiFi connected”);
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
// Initialize MQTT PubSub Library
client.setServer(MQTT_SERVER, MQTT_SERVERPORT);
// Function called in case of an incomming mqtt message from Cayenne Dashboard
// (In this case is the dashboard button to turn on/off the heater)
client.setCallback(mqttCallback);
Serial.println("DEBUG: Setup Done! ");
// -------------------- LOOOP -------------------
// Check if the esp8266 is connected to the mqtt server.
if (!client.connected()) {
reconnect();
// If connected, perform PubSubClient housekeeping function.
client.loop();
delay(500);
// ------------------------------ OTHER FUNCTIONS
// Function that attempts to reconnect to the mqtt server.
void reconnect() {
// If esp8266 is disconnected from the mqtt server, try to reconnect.
// (*** I still need to think what wil happen to the boiler if connection is lost ***)
while (!client.connected()) {
Serial.print(“DEBUG: Attempting MQTT connection…”);
if (client.connect(CLIENT_ID, MQTT_USERNAME, MQTT_PASSWORD)) {
  Serial.println("connected");
  // Once connected, resubscribe to the Dashboard on/off button topic.
  client.subscribe(MQTT_TOPIC_BTN_ONOFF);
} else {
  Serial.print("failed, rc=");
  Serial.print(client.state());
  Serial.println(" try again in 5 seconds");
  // Wait 5 seconds before retrying
  delay(5000);
Serial.println("DEBUG: Quiting reconnect loop ");
// Function to intercept MQTT messages
void mqttCallback(char* topic, byte* payload, unsigned int length) {
Serial.print(“Message arrived [”);
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
// Show the received message “stream” in the serial monitor.
Serial.print((char)payload[i]);
Serial.println();
// Delay for debugging purposes. If a message arrives from Cayenne, the terminal feed pauses 5’.
delay(5000);
nulla…sempre lo stesso errore
have you used two separate client_id here?
certo
try this code and see if you can connect atleast. https://github.com/spacefolder/esp8266-MQTT-v1/blob/master/esp8266-MQTT-v1.cpp
stesso errore "DEBUG: Attempting MQTT connection…failed, rc=-1 try again in 5 seconds
can you atleast connect using the cayenne library? https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino/blob/master/examples/Connections/ESP8266/ESP8266.ino
yes, uso tranquillamente cayenne da anni,per conferma ho provato ha inserire tutto sul’ hardware nuovo e cmq fuziona con la prova base che hai dato ora
you mean, it works with pubsub also?
no con pubsub no
ho provato anche ad aprire le porte sul router ,ma niente
