Hi. I’m looking for Smart Thermostat for heater on my bedroom that will work out of the box with Cayenne. I’m not programmer and I will not write code by myself. Is there some device
wchich works with Cayenne dashboard that I can buy and just connect to Cayenne?
Regards.
If you don’t want to program then you can go lora devices which are plug and play.
Can You tell me wchich devices I need to make that work?
I don’t see there aby thermostatic valves so that means there’s no devices compatybile with Cayenne?
well, one device wont do all the things until you buy a nest thermostat. You can add a temperature device and send its data to cayenne, then use a trigger to control the output device.
But do You know what models works with Cayenne without programming in python?
i am not sure which models you are referring to but the devices that are supported are listed in the link i shared earlier.
OK, thanks I will search something on that list.
