Hi, thanks for this info.
I have 2 questions
Can I change type value from digital_sensor to analog_sensor?
For a scale I want to use Kg as unit value, according to your table there is no Kg, so I use βdβ. Is there a possibility to use Kg as unit value?
I read the scale by a ACD type HX711.
I have this code for a scale, value I send is weigthKg
CAYENNE_OUT(VIRTUAL_CHANNEL_6) {
Cayenne.virtualWrite(VIRTUAL_CHANNEL_6, weightKg, "digital_sensor", "d");
M
digital_sensor
is used for digital state values like open/close or on/off.
you need to a generic datatype analog_sensor
for any unit which is not supported in our end.
Hi @shramik_salgaonkar thanks for reply.
I manage now to send analog data and I can see the graphs. I have sent data for 1 week
In the graph i can se Live, m and h, like this
For Day I see this
In section I see this
Why donβt I see any data under Data section?
M
Due to problems making Cayenne work for my devices I have changed to Home Assistant with influxDB and grafana dashboard.
