May i know that what is mean by" You will need to terminate the connection script
before uploading new sketches since it blocks access to the Serial port" because i just now try tutorial its work i able to upload dummy data to dashboard but now i cant upload the new sketch that just now you given
i can use this code already thanks tad but may i know that does the trigger function is down recently ?
Yes
if i want add gas sensor to this coding and i add this
"int analogValue = analogRead(A0);
int gas = map(analogValue, 0, 1023, 0, 100);
Cayenne.virtualWrite(3, gas, āanalog_sensorā, ānullā); "
below line of Cayenne.virtualWrite(2, event.relative_humidity, ārel_humā, āpā);
is this correct
Yes
May i know that how to change the word Analog in widget of gas sensor to percentage
i change the coding null to p also not changes
Alright thanks
Is that the the unit value inside the table is fix one or we change change it
i have never tried them interchanged but just made a simple example with this code:
Cayenne.virtualWrite(21, y, "analog_sensor", "p");
Cayenne.virtualWrite(22, y, "analog_sensor", "null");
but the change only can be seen in gauge widget and not in value widget. you can try diffferent combination.
I have my DHT11 working but Iām a bit puzzled by some of the peaks and troughs which seem suspiciously large and sudden. Whatās going on? Does it need some parameter tweeking? I donāt want to set up alarms and be getting false ones.
Hereās an example:
UPDATE: Aha! I found the line with time.time in __init.py. Changed +2 to +10 and the graph already seems better. Time will tell if thatās the solution.
LATER: No. Still getting these randoms huge peaks and troughs. Having done a bit more Googling, smoothing the data might be the only way forward. Itās too late to look at it properly now: [SOLVED] DHT sensor occasionally returning spurious values - #5 by RobertLucian - GrovePi - Dexter Industries Forum
can you try this code and see if you are getting any spikes in the reading Overview | DHT Humidity Sensing on Raspberry Pi or Beaglebone Black with GDocs Logging | Adafruit Learning System
Thanks, will check it out. Any thoughts as to which might be the best solution, yours or the one that I found? Iām a little nervous of the dire warning on the former
If I wanted to use this code, could I add it (bearing in mind mind Iām a Python virgin)? If so where? By digital port, does it mean GPIO. Currently, mine is on port 11 (labelled 17 on the cobbler), so will this need changing to 7 in the code?
I guess, as my sensor is blue, I delete āwhite = 1 # The White colored sensor.ā?
import grovepi
import math
import numpy
import threading
from time import sleep
from datetime import datetime
sensor = 4 # The Sensor goes on digital port 4.
# temp_humidity_sensor_type
blue = 0 # The Blue colored sensor.
filtered_temperature = [] # here we keep the temperature values after removing outliers
filtered_humidity = [] # here we keep the filtered humidity values after removing the outliers
lock = threading.Lock() # we are using locks so we don't have conflicts while accessing the shared variables
event = threading.Event() # we are using an event so we can close the thread as soon as KeyboardInterrupt is raised
# function which eliminates the noise
# by using a statistical model
# we determine the standard normal deviation and we exclude anything that goes beyond a threshold
# think of a probability distribution plot - we remove the extremes
# the greater the std_factor, the more "forgiving" is the algorithm with the extreme values
def eliminateNoise(values, std_factor = 2):
mean = numpy.mean(values)
standard_deviation = numpy.std(values)
if standard_deviation == 0:
return values
final_values = [element for element in values if element > mean - std_factor * standard_deviation]
final_values = [element for element in final_values if element < mean + std_factor * standard_deviation]
return final_values
# function for processing the data
# filtering, periods of time, yada yada
def readingValues():
seconds_window = 10 # after this many second we make a record
values = []
while not event.is_set():
counter = 0
while counter < seconds_window and not event.is_set():
temp = None
humidity = None
try:
[temp, humidity] = grovepi.dht(sensor, blue)
except IOError:
print("we've got IO error")
if math.isnan(temp) == False and math.isnan(humidity) == False:
values.append({"temp" : temp, "hum" : humidity})
counter += 1
#else:
#print("we've got NaN")
sleep(1)
lock.acquire()
filtered_temperature.append(numpy.mean(eliminateNoise([x["temp"] for x in values])))
filtered_humidity.append(numpy.mean(eliminateNoise([x["hum"] for x in values])))
lock.release()
values = []
def Main():
# here we start the thread
# we use a thread in order to gather/process the data separately from the printing proceess
data_collector = threading.Thread(target = readingValues)
data_collector.start()
if len(filtered_temperature) > 0: # or we could have used filtered_humidity instead
lock.acquire()
# here you can do whatever you want with the variables: print them, file them out, anything
temperature = filtered_temperature.pop()
humidity = filtered_humidity.pop()
print('{},{:.01f},{:.01f}' .format(datetime.now().strftime("%Y-%m-%d %H:%M:%S"), temperature, humidity))
lock.release()
# wait a second before the next check
sleep(1)
# wait until the thread is finished
data_collector.join()
if __name__ == "__main__":
try:
Main()
except KeyboardInterrupt:
event.set()
i could suggest to go with the simpler approach the one that i provided.
lets start with this:
on you raspberry install the following:
sudo apt-get update
sudo apt-get install python3-pip
sudo python3 -m pip install --upgrade pip setuptools wheel
sudo pip3 install Adafruit_DHT
cd Adafruit_Python_DHT
sudo python3 setup.py install
Once done navigate to examples folder and open the sketch:
sudo nano Adafruit_Python_DHT/examples/simpletest.py
in the code you need to make the following changes:
sensor = Adafruit_DHT.DHT22
to
sensor = Adafruit_DHT.DHT11
# Example using a Beaglebone Black with DHT sensor
# connected to pin P8_11.
pin = 'P8_11'
# Example using a Raspberry Pi with DHT sensor
# connected to GPIO23.
#pin = 23
to
#pin = 'P8_11'
pin = 17
you have connected your sensor to GPIO17. https://www.raspberrypi-spy.co.uk/wp-content/uploads/2012/06/Raspberry-Pi-GPIO-Layout-Model-B-Plus-rotated-2700x900.png
