ESP286612E DEV KIT doit.am - BLYNK won`t connect to WiFi
Hello friends,
i`m having issues connecting with my ESP286612E DEV KIT to my WiFi router. It is simple sketch i want to run and control via cayenne dashboard.
The code:
#include "CayenneDefines.h"
char token[] = "<8qghxxxxx>";
char ssid[] = "<Zombie>";
char password[] = "<zoxxxxxxm>";
  // initialize digital pin 2 as an output.
  pinMode(2, OUTPUT);
// This function will be called every time a Dashboard widget writes a value to Virtual Pin 2.
CAYENNE_IN(V2)
  CAYENNE_LOG("Got a value: %s", getValue.asStr());
  int i = getValue.asInt();
  if (i == 0)
    digitalWrite(2, LOW);
  else
    digitalWrite(2, HIGH);
I cant get far from serial port message:
So dashboard is waiting and waiting for board to connect…
I use:
  • Arduino IDE 1.6.12
  • NODEMCU 1.0 (ESP 12-E module)
  • ESP2866 board version 2.3.0
When “helloServer”[ESP2866WebServer] tested - it was done with no problem.
BR,
Matic
Hi @lxmatic ,
You shouldn’t use the < and > characters in your strings.
Also, can you try it without setting the pinMode first or use another pin? Some of the ESP pins have special functions and sometimes exhibit odd behavior.
Huh… what a mistake… THANK YOU Craig a BIG TIME :slight_smile: removing “<>” characters did the job.
Matic
Great!
If you see strange issues like resets, or outputs turning on without you setting them, try another pin.
