HI,
i’m using ESP-01 with Arduino IDE
i’m on Cayenne WEB & ANDROID dashboard
My projects (ESP8266) send the data of my sensors every 5 minutes to Cayenne. If it restart, he also sends the last measurements.
Is there a function in the Arduino Cayenne library for ESP8266 (Mqtt) that tells me if a client is connected? Ex: I open the app on my smartphone, or i open my Dashboard on my pc.
I could then send the status of the sensors live, and avoid waiting for the 5 minutes of refresh.
yes, check this link out. If your using MQTT you don’t need to edit the library, it already is setup for it. Just call those functions and you can set a LED or something to indicate if its online or not. Not sure if this is exactly what you looking for but its what I use.
to know if my device is good connected to “mqqt” cayenne, that is always true because the connection working good all time (ex: when i “power on” my ESP or reset).
BUT : the thing i want is to know if someone open the dashboard on the web or on smartphone , at this time, my ESP device detect it, and send all data to cayenne immediately (without waiting 5 minutes).
Why ? Because (for the moment, i hope resolved in future) when i open Cayenne Dashboard it said “server error” or “blanc” widget without data. I’m waiting few seconds (because i send refresh data all 30sec) and all data appear !
+Because we are on 21 century and i don’t want to wait 30s
ahh I see. I don’t think thats possible currently for data refresh on smartphone/web connection. I would add this to the Ideas/Suggestions category and maybe they will add it in the future.
What you could do, is add a “REFRESH” button on the dashboard.
If pressed, it could call a functionRefresh(); that manually sends the values to the dashboard.
It should work fine!
BTW, it´s a great idea, since I´m facing the same problem of not wanting to wait 1 minute.
So I´ll try to code the function and share it as soon as I have some spare time.
The code is based upon the default Cayenne ESP8266 sketch, which sends the “seconds elapsed” since boot, every 30 seconds to channel 0.
YOU MUST create a button on the Dashboard and assign it to Channel 1.
[Add new… > Device/Widget > Custom Widgets > Button]
Enter a name for the button (REFRESH in this case)
Select Device
Data type: Digital Actuator
Channel number: 1
Choose an icon
Add Widget to the dashboard!
This function will “force” a refresh when the button is pressed.
It will send the updated millis value to the Dashboard immediately, without having to wait 30 seconds till next update.
Hope it helps.
Cheers!
Marc
//#define CAYENNE_DEBUG
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
unsigned long lastMillis = 0;
//Publish data every 30 seconds (30000 milliseconds).
if (millis() - lastMillis > 30000) {
lastMillis = millis();
Cayenne.virtualWrite(0, (lastMillis / 1000));
// !! YOU MUST create a button on the Dashboard ad assign it to Channel 1.
// [Add new... > Device/Widget > Custom Widgets > Button]
// 1) Enter a name for the button (REFRESH in this case)
// 2) Select Device
// 3) Data type: Digital Actuator
// 4) Channel number: 1
// 5) Choose an icon
// 6) Add Widget to the dashboard!
// This function will "force" a refresh when the button is pressed.
// It will send the updated millis value to the Dashboard immediately,
// without having to wait 30 seconds till next update!
CAYENNE_IN(1) {
Cayenne.virtualWrite(0, (millis() / 1000));
good job Marc
Perhaps , in futur, device will be able to do that automatically with only 1 function like :
CAYENNE_CLIENT_CONNECTED()
CAYENNE_LOG("A Client is connected !");
Serial.println("Someone Open Cayenne Dashboard and connected to this device.");
sendDataToCayenne(); //go to function : send all data immediately
