Ethernet module enc28j60
can I use an ethernet module instead the ethernet sheild ?
Does it support ENC28J60 module?
Which module do you have in mind?
enc28j60
Is ENC28J60 supported
Looks like it’s supported by Blynk, so it will potentially work with Cayenne.
@kreggly @ I just ordered this ethernet module and will try it out. @mariomedhat9 Let us know if you can get it working!
ok
thank you verry much :smiley:
I don’t have this module, but I slapped some code together.
Install the arduino_uip library, wire up you pins as defined in the comments, and give it a go:
@bestes, did you get one yet?
 * For this example you need UIPEthernet library:
 *   https://github.com/ntruchsess/arduino_uip
 * Wire it up:
 *  VCC -- 5V
 *  GND -- GND
 *  CS  -- D10
 *  SI  -- D11
 *  SCK -- D13
 *  SO  -- D12
 *  INT -- D2
#include <CayenneDefines.h>
#include <UIPEthernet.h>
#include <BlynkSimpleUIPEthernet.h>
#include <CayenneEthernetClient.h>
char token[] = "YOUR TOKEN"; //NOT MY TOKEN
  Cayenne.begin(token);
I have one. I’ll have to find it first but can probably test tomorrow if it’s not buried somewhere.
Finally found it after looking for my GPS module (which I didn’t find :’( )
Confirming it works fine. You have to install the UIPEthernet library from https://github.com/ntruchsess/arduino_uip which gives some annoying warnings in the compile output, but hey it works, right?
