I want to control my heating system with Cayenne, and I want to do it low cost. So, no expensive brand RF thermothates.
Wishlist:
Most of the rooms floor heating.
A few rooms radiator heating.
Every room his own temperature control.
Every room a small tablet for Cayenne (light switching, equipment switching, temperature control).
My simple thoughts:
Every room a temperature sensor (Raspberry PI zero Wifi with temperature sensor).
Every floor heating group a actuator (Raspberry PI zero Wifi with actuator).
Every radiator a actuator (Raspberry PI zero Wifi with actuator).
In Domoticz modules (I don’t know the right description) where I can type in or turn up/down the temperature I want for that room.
Scripts that compare the measured temperature and the wanted temperature per room and (de)activate the actuator for that room/group or radiator.
Who has experience with this, can help me?
Rob
bestes
March 8, 2017, 2:15pm
2
Hi Rob,
You can browse the Cayenne Projects category to get a feel for what some Cayenne members have made for their heating systems.
@Bill has experience with the Pi Zero and fully automating the home, he may be able to give you some advice
Bill
March 8, 2017, 6:05pm
3
Yes- been there, done that.
Easy peasey.
Hello Bill,
Thanks for your reply.
Can I get some information about it?
Since today I have Cayenne. I use it with a Raspberry PI and I can measure temperature and switch on a relais when the temperature is above a certain level and switch of when it is below a certain level.
But now: how can I adjust that level on my dashboard, and not in the trigger edit mode?
Rob
Bill
March 8, 2017, 6:57pm
5
slider widget-
yes, you guessed correctly about the trigger mode. NOT the best way-
As far as I know, the only way to plug a variriable into Cayenne is by using the SLIDER widget. i’m not SURE about that, either.
For what I understand is that you only can use a slider if you have a device connected that can use a slider value.
It would be nice if you can fill a variabel with a slider value and use that variabel in the trigger.
I wonder if you can use a variabel?
Bill
March 8, 2017, 7:23pm
7
The SLIDER widget is a virtual thingie,
so you should be able to send it’s value to an if/then statement in triggers…
I HAVE sent positioning data TO a servo motor
using triggers and set positioning values, so I know it works.
That would be nice, but if you choose Add a widget Slider it asks for a device.
In the tutorail it also says:
Change the value of the connected device, such as dimming a light. The units, MIN and MAX values can be adjusted in settings.
So, it is not a virtual thing.
Bill
March 8, 2017, 7:42pm
9
It works 4 me-
Select ANY device and add a slider-
The device in the my example is a Sonoff Switch .
-Perhaps @adam knows more about Slider widget.
As you can see, in my case Cayenne wants me to select a device in the right side of the screen. If I place my mouse on top of it, it gives a red NO symbol.
The second thing is: how can I define a variabel?
I have run in the same issue with selecting the device. Try adding an Actuator->Generic->PWM Output, the widget type should be a slider.
As far as setting a variable from the slider, I use a slider for setting a motion sensor timeout value that is passed back to the device and set as a variable. You just need to use a CAYENNE_IN(VPIN ) function to get the value from the slider. The VPIN is actually going to be whatever Virtual PIN number you assign to the slider, for example V8.
Bill
March 8, 2017, 8:38pm
12
Awesome!
Yes- I believe that when I accomplished it before, -I had installed a PWM extention. Exactly!
-my memory is a bit mushy.
I only went to 1 Grateful Dead concert-
from 1982 until 1995.
It was a long, strange trip.
It aproves that you are only human!
Hello Andre,
Can you please be a little more specific because I am new in Cayenne and I don’t know how I can make/use a CAYENNE_IN(VPIN) function.
It would be nice if you can make a step by step explanation.
Thank you.
I have the idea that this is working for a Arduino environment, but I am using a Raspberry PI.
adam
March 16, 2017, 5:02pm
17
If you are using a Pi you will have to go with the MQTT API for custom widgets. Cayenne Docs Let me know if you need any help!
