Raspberry Pi 3, latest Raspian Jessie. So I have a project that’s using a TSL2561 light sensor and when the sun is shining directly at it the sensor is overwhelmed and it reports an eronious number (364). Looking into the data sheets on this device shows that it has a gain adjustment and the ability to reduce the frequency of readings which would help in this particular situation. However, as I’m running it through Cayenne I don’t believe I can adjust those parameters.
My other option is to give the sensor some sunglasses and reduce the amount of light going in. I’d prefer to get as accurate a reading as possible, but if that’s all I can do at this time then so be it. Anyone else bump into this before?
