List of connectivity only see "Virtual"
Hi community… I’m doing a simple LED light with Arduino uno, So my List of connectivity only see “Virtual” . I don’t use ethernet Shield, I use usb Connectivity.
thks
you have to select virtual connectivity, then add the channel you want and write your code accordingly.
for above case, the code will be.
CAYENNE_IN(12) {
  int value = getValue.asInt();
  digitalWrite(light_pin, value);
thank shramiksalgaonkar
it works now…
