Sensors not working/triggers wont save
Having trouble with two of four temp sensors not dispaying accurate temp. Just show -197
the two that are working cant save triggers either dont save or appear to save but revert back to default. Using arduino uno with 18b20 temp sensors below is my code
 // This example shows how to connect to Cayenne using an Ethernet W5500 shield and send/receive sample data.
//#define CAYENNE_DEBUG
//#include <CayenneMQTTEthernet.h>
#include <CayenneMQTTEthernetW5500.h>
 #include <OneWire.h>
char username[] = "bd4a1000-a9d3-11e6-82ee-87310fcf8579";
char password[] = "bada44eda9a38dd862c5a1afc0809579a6d882a9";
char clientID[] = "09709a20-6a81-11e8-a76a-fdebb8d0010d";
unsigned long lastMillis = 0;
#define VIRTUAL_CHANNEL4 4
#define VIRTUAL_CHANNEL5 5
#define VIRTUAL_CHANNEL6 6
#define VIRTUAL_CHANNEL7 7
const int tmpPin7 = 7;
const int tmpPin6 = 6;
const int tmpPin5 = 5;
const int tmpPin4 = 4;
OneWire oneWire7(tmpPin7);
OneWire oneWire6(tmpPin6);
OneWire oneWire5(tmpPin5 );
OneWire oneWire4(tmpPin4);
DallasTemperature sensors7(&oneWire7);
DallasTemperature sensors6(&oneWire6);
DallasTemperature sensors4(&oneWire4);
  sensors4.begin();
  sensors5.begin();
  sensors6.begin();
  sensors7.begin();
CAYENNE_OUT(VIRTUAL_CHANNEL4)
  sensors4.requestTemperatures();
  //Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors6.getTempCByIndex(0));
  Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL4, sensors4.getTempFByIndex(0));
CAYENNE_OUT(VIRTUAL_CHANNEL5)
  //Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors5.getTempCByIndex(0));
  Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL5, sensors5.getTempFByIndex(0));
CAYENNE_OUT(VIRTUAL_CHANNEL6)
  sensors6.requestTemperatures();
  Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL6, sensors6.getTempFByIndex(0));
CAYENNE_OUT(VIRTUAL_CHANNEL7)
  sensors7.requestTemperatures();
  Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL7, sensors7.getTempFByIndex(0));
first try to get reading from the sensor http://arduino-info.wikispaces.com/MultipleTemperatureSensorsToLCD
I had not planned to use 18b20 on one wire had this project set up before mqtte worked fine after trying to convert over is when above problems occured. Plugging in each temp sensor i seperate they populated fine but taking project back to storage hooking up all four only two poipulated properly. can sensors not be used seperalty and apart on own channel with mqtte??
Dave
can you post the code you used without cayenne MQTT which worked fine for multiple temp readings. Are you getting reading from the each sensor without cayenne code.
i used cayenne code
Cayenne DS18B20 Example
This sketch shows how to send temperature data to a DS18B20 Sensor in the Cayenne Dashboard.
Steps:
  1. Install the OneWire library (OneWire Arduino Library, connecting 1-wire devices (DS18S20, etc) to Teensy) from the Arduino Library Manager.
  2. Install the DallasTemperature library (Miles Burton - Innovative engineering for pretty much anything) from the Arduino Library Manager.
  3. In the Cayenne Dashboard add a new DS18B20 widget.
  4. Set the widget to Value Display.
  5. Select Virtual Pins and a virtual pin number.
  6. Set VIRTUAL_PIN to the pin number you selected.
  7. Attach a DS18B20 to an digital pin on your Arduino.
    Schematic:
    [Ground] – [DS18B20] – [4.7k resistor] – [5V]
    |______________|
    Digital Pin
  8. Set the tmpPin variable to match the pin used to connect the DS18B20.
  9. Set the token variable to match the Arduino token from the Dashboard.
  10. Compile and upload this sketch.
  11. Once the Arduino connects to the Dashboard it should automatically update the DS18B20 widget with data.
#include <CayenneEthernetW5500.h>
#define VIRTUAL_PIN1 V1
#define VIRTUAL_PIN2 V2
#define VIRTUAL_PIN3 V3
const int tmpPin1 = 7;
const int tmpPin2 = 6;
const int tmpPin3 = 5;
OneWire oneWire1(tmpPin1);
OneWire oneWire2(tmpPin2);
OneWire oneWire3(tmpPin3);
DallasTemperature sensors1(&oneWire1);
DallasTemperature sensors2(&oneWire2);
DallasTemperature sensors3(&oneWire3);
char token = “luhbdjf5h”;
Cayenne.begin(token);
sensors1.begin();
sensors2.begin();
sensors3.begin();
CAYENNE_OUT(VIRTUAL_PIN1)
sensors1.requestTemperatures();
Cayenne.celsiusWrite(VIRTUAL_PIN1, sensors1.getTempCByIndex(0));
CAYENNE_OUT(VIRTUAL_PIN2)
sensors2.requestTemperatures();
Cayenne.celsiusWrite(VIRTUAL_PIN2, sensors2.getTempCByIndex(0));
CAYENNE_OUT(VIRTUAL_PIN3)
sensors3.requestTemperatures();
Cayenne.celsiusWrite(VIRTUAL_PIN3, sensors3.getTempCByIndex(0));
Try this code and see if you are getting value from sensor.
#include &lt;OneWire.h&gt;
#include &lt;DallasTemperature.h&gt;
DallasTemperature sensors1(&amp;oneWire1);
DallasTemperature sensors2(&amp;oneWire2);
DallasTemperature sensors3(&amp;oneWire3);
sensors1.begin();
sensors2.begin();
sensors3.begin();
int x;
int y;
int z;
x = sensors1.getTempCByIndex(0)
delay(100);
xy= sensors2.getTempCByIndex(0)
z = sensors3.getTempCByIndex(0)
Serial.print(x);
Serial.print(y);
Serial.println(z);
cant get code to verify hangs up on
#include <DallasTemperature.h> # include expects “filename” or
sensors1.begin();
sensors2.begin();
sensors3.begin();
int x;
int y;
int z;
x = sensors1.getTempCByIndex(0);
delay(100);
y= sensors2.getTempCByIndex(0);
delay(100);
delay(100);
z = sensors3.getTempCByIndex(0);
Serial.print(x);
Serial.print(y);
Serial.println(z);
code uploaded ok serial monitor has 22-127-127 the first two numbers appear to be temp c
it goes up and down with temp it only shows up with sensor #1 so am i back to square 0ne?
the tutorial you sent me to use sensors on one wire even if i get that figured out the code still has to be converted to cayenne MQTT right? Not much on coding been getting by put and take. Nor sure where to go from here
First try to get the sensor reading using the tutorial i send above. once you have done that, we can move forward with cayenne code.
Also for the above output (22-127-127), try swapping the order for getting the temperature in the code and post the entire Serial output screenshot.
delay(100);
delay(100);
delay(100);
Serial.print(x);
Serial.print(y);
Serial.println(z);
switched order serial print screen look as before switching
-127 is an issue reported for bad connection. try this One wire probe problem - #2 by shramik_salgaonkar
Got code off sensors when i go to hook them up what will be best to work with cayenne alerting system 1 arduino uno pin doing true one wire hooking 4 sensors or 4 arduino uno pins to hook 4 sensors not using onnly one pin or does it matter??
you can use which ever you want until you are getting the temperature reading from the sensor. then send the data of each sensor to cayenne using:
    Cayenne.celsiusWrite(1, temp1);
    Cayenne.celsiusWrite(2, temp2);
    Cayenne.celsiusWrite(3, temp3);
where temp1, temp2, temp3 are data of each sensor.
Got all sensors working (see screen capture below) with arduino sketch shown below. Now i need to to convert to cayenne sent with ethernet shield 5500. Can you help to convert sketch to get this working again?
Dave
 //  This Arduino sketch reads DS18B20 "1-Wire" digital
//  temperature sensors.
//  Copyright (c) 2010 Mark McComb, hacktronics LLC
//  License: http://www.opensource.org/licenses/mit-license.php (Go crazy)
//  Tutorial:
//  http://www.hacktronics.com/Tutorials/arduino-1-wire-tutorial.html
// Data wire is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 3
// Setup a oneWire instance to communicate with any OneWire devices
// Pass our oneWire reference to Dallas Temperature.
// Assign the unique addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress  ColdStorage1Thermometer = { 0x28,0xFF,0xAC,0xCF,0x02,0x17,0x04,0x55 };
DeviceAddress  CooldStorage2Thermometer = { 0x28,0xFF,0x6E,0xED,0x02,0x17,0x03,0x00 };
DeviceAddress  ColdStorage3Thermometer = { 0X28,0xFF,0x34,0x58,0x02,0x17,0x05,0xE5 };
DeviceAddress  GH1Thermometer        =   { 0x28 ,0xFF,0xA2,0xCD,0x02,0x17,0x03,0x73 };
void setup(void)
  // start serial port
  // Start up the library
  sensors.begin();
  // set the resolution to 10 bit (good enough?)
  sensors.setResolution( ColdStorage1Thermometer, 10);
  sensors.setResolution( CooldStorage2Thermometer, 10);
  sensors.setResolution(ColdStorage3Thermometer, 10);
  sensors.setResolution(GH1Thermometer, 10);
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  if (tempC == -127.00) {
    Serial.print("Error getting temperature");
  } else {
    Serial.print("C: ");
    Serial.print(tempC);
    Serial.print(" F: ");
    Serial.print(DallasTemperature::toFahrenheit(tempC));
void loop(void)
  delay(2000);
  Serial.print("Getting temperatures...\n\r");
  Serial.print("ColdStorage1 temperature is: ");
  printTemperature(ColdStorage1Thermometer);
  Serial.print("\n\r");
  Serial.print("CooldStorage2 temperature is: ");
  printTemperature(CooldStorage2Thermometer);
  Serial.print("ColdStorage3 temperature is: ");
  printTemperature(ColdStorage3Thermometer);
  Serial.print("\n\r\n\r");
   Serial.print("GH1 temperature is: ");
  printTemperature(GH1Thermometer);
in your arduino IDE navigate to File → examples → CayenneMQTT → Sensors and open DS18B20.ino.
Make changes and add you sensor code to this.
Here is the sketch i combined cant get to compile, [ virtual channel was not declared in this scope]
not sure how to set up virtual channels with only one wire pin on arduino
dave
//  Tutorial:
#include <OneWire.h>// Cayenne authentication info. This should be obtained from the Cayenne Dashboar
DeviceAddress insideThermometer = { 0x28, 0x94, 0xE2, 0xDF, 0x02, 0x00, 0x00, 0xFE };
DeviceAddress outsideThermometer = { 0x28, 0x6B, 0xDF, 0xDF, 0x02, 0x00, 0x00, 0xC0 };
DeviceAddress dogHouseThermometer = { 0x28, 0x59, 0xBE, 0xDF, 0x02, 0x00, 0x00, 0x9F };
void setup(void)
  sensors.begin();
void loop(void)
CAYENNE_OUT(VIRTUAL_CHANNEL)
  // Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors.getTempCByIndex(0));
   Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL, sensors.getTempFByIndex(0));
// This Arduino sketch reads DS18B20 “1-Wire” digital
//  Tutorial:
void setup(void)
  sensors.begin();
void loop(void)
why have you posted two codes?
Add this line in your code:
#define VIRTUAL_CHANNEL 1
got things working but only picking up one sensor sensor 3
using following sketch
// License: The MIT License | Open Source Initiative (Go crazy)
// Tutorial:
// Arduino 1-Wire Tutorial
char username = “bd4a1000-a9d3-11e6-82ee-87310fcf8579”;
char password = “bada44eda9a38dd862c5a1afc0809579a6d882a9”;
char clientID = “09709a20-6a81-11e8-a76a-fdebb8d0010d”;
#define VIRTUAL_CHANNEL 2
#define VIRTUAL_CHANNEL 3
#define VIRTUAL_CHANNEL 4
// Arduino 1-Wire Address Finder
void setup(void)
sensors.begin();
void loop(void)
you will have to add code for reading temperature from other sensor and send them using virtual channel 2 and 3 similar way you did for channel 1.
