Servo control?
Looking to drive a standard little servo motor (0 to 180 degrees) using a slider control. Can anyone share a tutorial on how to do this or point me to any reference projects? Google and searching the community projects not helping too much.
Many Thanks,
tett
add a custom slider widget with channel 1 and set minimum position to 0 and maximum to 180 with slider step value to 1.
next add this code:
CAYENNE_IN(1)
  int x= getValue.asInt();
myservo.write(x);
Looks very easy so I tried in a program but got an error when test compiling.
/Users/tett/Documents/Arduino/Cayenne_Wemos_test/Cayenne_Wemos_test.ino: In function ‘void loop()’:
Cayenne_Wemos_test:29: error: a function-definition is not allowed here before ‘{’ token
And, following is the code in question:
#include<Servo.h>
Servo servo;
char ssid[] = “”;char wifiPassword[] = “”;
char username[] = “”;
char password[] = “”;
char clientID[] = “”;
long lastMillis = 0;int x = 0;
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
servo.attach(2);
CAYENNE_IN(1)
int y= getValue.asInt();
myservo.write(y);
//Publish data every 1 seconds (1000 milliseconds). Change this value to publish at a different interval.
if (millis() - lastMillis > 100) {
lastMillis = millis();
x = digitalRead(4);
Cayenne.virtualWrite(1, x, “digital_sensor”, “d”);
try this
#include<Servo.h>
Servo servo;
pinMode(4, OUTPUT);
servo.attach(2);
x = digitalRead(4);
CAYENNE_IN(1)
myservo.write(y);
This is working well. Many thnaks for your input.
