I’d like to use sliders to choose colors, so I don’t need any unit on the slider; just numbers. I tried to make it a distance slider with inches as units so it only shows a ". But would it be possible to make a slider just for numbers?
this is possible if you use MQTT and a custom slider.
Actually I found a solution: make a Volage slider with unit as “integer” or “float”. This does not display any unit text.
