This is my code for MPU6050.
Cayenne-MPU6050.txt (1.4 KB)
Hi @tad.dvor,
This could be useful. I added some comments and changed variable names. Thx, Craig
#include "Wire.h"
#include "Math.h"
#include "I2Cdev.h"
#include "MPU6050.h"
#include <CayenneEthernet.h>
#define VIRTUAL_PINX V2
#define VIRTUAL_PINY V3
MPU6050 accelerometer;
const float pi = 3.141592;
const int avg_max = 100;
int16_t ax, ay, az;
float x, y, z;
int avg_count;
float _angle_x, angle_x, _angle_y, angle_y;
long ax_avg, ay_avg, az_avg;
char token[] = "token";
Serial.begin(38400);
Wire.begin();
Cayenne.begin(token);
Serial.println("Cayenne Connected...");
accelerometer.initialize();
if (accelerometer.testConnection()) {
Serial.println("Accelerometer Connected...");
//process Cayenne
//read accelerometer
accelerometer.getAcceleration(&ax, &ay, &az);
//accumulate averages
ax_avg = ax_avg + ax;
ay_avg = ay_avg + ay;
az_avg = az_avg + az;
avg_count++;
//got all the sample?
if (avg_count == avg_max)
//calculate averages
x = ax_avg/avg_max;
y = ay_avg/avg_max
z = az_avg/avg_max
//compute angles
angle_x = atan2(x, sqrt(square(y) + square(z)) )/(pi/180);
angle_y = atan2(y, sqrt(square(x) + square(z)) )/(pi/180);
//initialize for next pass
avg_count = 0;
ax_p = 0;
ay_p = 0;
az_p = 0;
//print results
Serial.print(angle_x);
Serial.print("\t");
Serial.println(angle_y);
CAYENNE_OUT(VIRTUAL_PINX)
Cayenne.virtualWrite(VIRTUAL_PINX, angle_x);
CAYENNE_OUT(VIRTUAL_PINY)
Cayenne.virtualWrite(VIRTUAL_PINY, angle_y);
Thanks, I forgot to translate it from Czech into English
Tadeas
No problem. Keep coding, I am happy to translate.
Used to work for a Japanese company, so I have lots of practice ![]()
Well done sir!
@kreggly is right, this code could be really useful. Thanks for submitting this! Iām ordering MPU6050 sensor now ![]()
