Welcome to my living room (IR + 433MHz + RGB LED stips)
Hi guys!
I just updated my project to make it fully compatible with Arduino board. I was forced to make many changes, especially because of the PWM pins in my Arduino UNO + Ethernet shield. It was not easy but it working :wink:
After reading a thousand times Arduino documentation about analogWrite & PWM, I was forced to update my sketch + wiring. (I’m web developer and I have some knowledge in electrical but I need to improve my wiring skills because It’s still the beginning for me in Arduino world. My best friend offered me a Arduino Starter kit for my birthday only 4 months ago… :gift: :heart_eyes:
It would be easier if I had Arduino Mega because it has more available PWM pins but I didn’t buy this kind of Arduino board yet. Bad choice for me :frowning:
Fist of all, I had to connect my RGB LED strips together. It allows me to get more PWM pins to plug my hardware:
  • 1 x 433MHz transmitter
  • 1 x IR LED
  • 1 x ULN2803 (instead of 2)
Then, I had to update IRremoteInt.h (from IRremote library) to force to use another Timer with PWM Pin #9 instead of PWM Pin #3. (Because my PWM Pin #3 is already used by RGB LED strips)
// Arduino Duemilanove, Diecimila, LilyPad, Mini, Fio, Nano, etc
#else
	#define IR_USE_TIMER1   	// tx = pin 9
	//#define IR_USE_TIMER2    // tx = pin 3
#endif
Then, I plugged:
  • LED strip Blue to PWM pin 3
  • LED strip Red to PWM pin 5
  • LED strip Green to PWM pin 6
  • IR LED to PWM pin 9
  • 433MHz transmitter to PWM pin 10
Then, I had to update my sketch:
#define CAYENNE_PRINT Serial
#include "CayenneDefines.h"
#include "RCSwitch.h"
#include "IRremote.h"
#include "CayenneEthernet.h"
char token[] = "XXXXXXXXXX";        //your Cayenne token
int loadingTimeChaconZap = 20000;   //enable 433MHz 20 seconds after board boot
#define VIRTUAL_PIN_0 V0    //uptime
#define VIRTUAL_PIN_6 V6    //led R
#define VIRTUAL_PIN_7 V7    //led V
#define VIRTUAL_PIN_8 V8    //led B
//Chacon
#define VIRTUAL_PIN_9 V9    //Chacon2
#define VIRTUAL_PIN_10 V10  //Chacon3
#define VIRTUAL_PIN_11 V11  //Chacon4
//Zap
#define VIRTUAL_PIN_12 V12  //Zap1
#define VIRTUAL_PIN_13 V13  //Zap2
#define VIRTUAL_PIN_14 V14  //Zap3
#define VIRTUAL_PIN_15 V15  //Zap4
//All
#define VIRTUAL_PIN_16 V16  //turn on/off all Chacon + Zap
#define VIRTUAL_PIN_17 V17  //turn on/off all Zap
#define VIRTUAL_PIN_18 V18  //turn on/off all Chacon
//IR LED lamp
#define VIRTUAL_PIN_23 V23  //IR LED lamp
//433MHz
RCSwitch mySwitch = RCSwitch();
int transmit_pin = 10;
int pulseLength = 185;
int repeatTransmit = 5;
int transmitterDelay = 100;  //Delay between 433 transmitter actions
//RGB LED strip
int LED_STRIP_2_BLUE  = 3;
int LED_STRIP_2_RED   = 5;
int LED_STRIP_2_GREEN = 6;
//IR
IRsend irsend;
  //Serial
  //Init LED
  pinMode(LED_STRIP_2_RED, OUTPUT);
  pinMode(LED_STRIP_2_GREEN, OUTPUT);
  pinMode(LED_STRIP_2_BLUE, OUTPUT);
  //433MHz Transmitter
  mySwitch.enableTransmit(transmit_pin);
  mySwitch.setPulseLength(pulseLength);
  mySwitch.setRepeatTransmit(repeatTransmit);
  //LED strip is green
  analogWrite(LED_STRIP_2_RED, 0);
  analogWrite(LED_STRIP_2_GREEN, 255);
  analogWrite(LED_STRIP_2_BLUE, 0);
  //Cayenne
  Cayenne.begin(token);
//Uptime
CAYENNE_OUT(VIRTUAL_PIN_0){
  int uptime = millis() / 1000;
  Cayenne.virtualWrite(VIRTUAL_PIN_0, uptime);
//Led RED
CAYENNE_IN(VIRTUAL_PIN_6)
  if(millis() > loadingTimeChaconZap){
    float currentValue = getValue.asDouble();
    currentValue = currentValue / 1023;
    int led2RED = currentValue;
    setLED2Red(led2RED);  // custom red
//Led GREEN
CAYENNE_IN(VIRTUAL_PIN_7)
    int led2GREEN = currentValue;
    setLED2Green(led2GREEN);
//Led BLUE
CAYENNE_IN(VIRTUAL_PIN_8)
    int led2BLUE = currentValue;
    setLED2Blue(led2BLUE);
//Chacon 2 on/off
CAYENNE_IN(VIRTUAL_PIN_9)
    int currentValue = getValue.asInt(); // 0 to 1
    if(currentValue == 1){
      chacon2_on();
    else{
      chacon2_off();
//Chacon 3 on/off
CAYENNE_IN(VIRTUAL_PIN_10)
    if(getValue.asInt() == 1){
      chacon3_on();
    else{
      chacon3_off();
//Chacon 4 on/off
CAYENNE_IN(VIRTUAL_PIN_11)
      chacon4_on();
    else{
      chacon4_off();
//Zap 1 on/off
CAYENNE_IN(VIRTUAL_PIN_12)
      zap1_on();
    else{
      zap1_off();
//Zap 2 on/off
CAYENNE_IN(VIRTUAL_PIN_13)
      zap2_on();
    else{
      zap2_off();
//Zap 3 on/off
CAYENNE_IN(VIRTUAL_PIN_14)
      zap3_on();
    else{
      zap3_off();
//Zap 4 on/off
CAYENNE_IN(VIRTUAL_PIN_15)
      zap4_on();
    else{
      zap4_off();
//turn on/off all
CAYENNE_IN(VIRTUAL_PIN_16)
      turn_on_all();
    else{
      turn_off_all();
//turn on/off Zaps
CAYENNE_IN(VIRTUAL_PIN_17)
      zap_on();
    else{
      zap_off();
//turn on/off Chacons
CAYENNE_IN(VIRTUAL_PIN_18)
      chacon_on();
    else{
      chacon_off();
//IR Slider
CAYENNE_IN(VIRTUAL_PIN_23) {
    if(currentValue == 85){
      irsend.sendNEC(0xFF1AE5, 32);
      Serial.println("Circle is RED");
    if(currentValue == 170){
      irsend.sendNEC(0xFF9A65, 32);
      Serial.println("Circle is GREEN");
    if(currentValue == 255){
      irsend.sendNEC(0xFFA25D, 32);
      Serial.println("Circle is BLUE");
//Set LED strip custom RVB color by strip id
void setColorLED(int red, int green, int blue, int strip)
  #ifdef COMMON_ANODE
    red = 255 - red;
    green = 255 - green;
    blue = 255 - blue;
  #endif
  analogWrite(LED_STRIP_2_RED, red);
  analogWrite(LED_STRIP_2_GREEN, green);
  analogWrite(LED_STRIP_2_BLUE, blue);
//Set LED custom Red value 0 - 255
void setLED2Red(int red)
  #ifdef COMMON_ANODE
    red = 255 - red;
  #endif
//Set LED custom Green value 0 - 255
void setLED2Green(int green)
  #ifdef COMMON_ANODE
  #endif
//Set LED custom Blue value 0 - 255
void setLED2Blue(int blue)
  #ifdef COMMON_ANODE
    blue = 255 - blue;
  #endif
void chacon2_on(){
  mySwitch.sendTriState("0FFFF0FFFFFF"); delay(transmitterDelay); //Serial.println("Chacon #2: ON");
void chacon3_on(){
  mySwitch.sendTriState("0FFFFF0FFFFF"); delay(transmitterDelay); //Serial.println("Chacon #3: ON");
void chacon4_on(){
  mySwitch.sendTriState("0FFFFFF0FFFF"); delay(transmitterDelay); //Serial.println("Chacon #4: ON");
void chacon2_off(){
  mySwitch.sendTriState("0FFFF0FF0000"); delay(transmitterDelay); //Serial.println("Chacon #2: OFF");
void chacon3_off(){
  mySwitch.sendTriState("0FFFFF0FFFF0"); delay(transmitterDelay); //Serial.println("Chacon #3: OFF");
void chacon4_off(){
  mySwitch.sendTriState("0FFFFFF0FFF0"); delay(transmitterDelay); //Serial.println("Chacon #4: OFF");
void zap1_on(){
  mySwitch.sendTriState("F00F0FFF0101"); delay(transmitterDelay); //Serial.println("Zap #1: ON");
void zap2_on(){
  mySwitch.sendTriState("F00F0FFF1001"); delay(transmitterDelay); //Serial.println("Zap #2: ON");
void zap3_on(){
  mySwitch.sendTriState("F00F0FF10001"); delay(transmitterDelay); //Serial.println("Zap #3: ON");
void zap4_on(){
  mySwitch.sendTriState("F00F0F1F0001"); delay(transmitterDelay); //Serial.println("Zap #4: ON");
void zap1_off(){
  mySwitch.sendTriState("F00F0FFF0110"); delay(transmitterDelay); //Serial.println("Zap #1: OFF");
void zap2_off(){
  mySwitch.sendTriState("F00F0FFF1010"); delay(transmitterDelay); //Serial.println("Zap #2: OFF");
void zap3_off(){
  mySwitch.sendTriState("F00F0FF10010"); delay(transmitterDelay); //Serial.println("Zap #3: OFF");
void zap4_off(){
  mySwitch.sendTriState("F00F0F1F0010"); delay(transmitterDelay); //Serial.println("Zap #4: OFF");
//turn on all Zap
void zap_on(){
    zap1_on(); zap2_on(); zap3_on(); zap4_on();
//turn off all Zap
void zap_off(){
    zap1_off(); zap2_off(); zap3_off(); zap4_off();
//turn on all Chacon
void chacon_on(){
    chacon2_on(); chacon3_on(); chacon4_on();
//turn off all Zap
void chacon_off(){
    chacon2_off(); chacon3_off(); chacon4_off();
//turn on all
void turn_on_all(){
    //Turn ON Chacon
    chacon4_on(); //chacon2_on(); chacon3_on();
    delay(10);
    //Turn ON Zap
    delay(10);
    //Turn ON LED Strip
    setColorLED(0, 255, 0, 2);
//turn off all
void turn_off_all(){
    //Turn OFF Chacon
    chacon4_off(); //chacon2_off(); chacon3_off();
    delay(10);
    //Turn OFF Zap
    delay(10);
    //Turn OFF LED Strip
    setColorLED(0, 0, 0, 2);
With this updated sketch, it’s working :wink:
I created new Trigger to change circle light color automatically. For example, if I set LED strip to Blue, trigger sends an IR value to set the circle light to blue.
At last, I create new Cayenne dashboard to controle my living room devices.
Thanks to Cayenne, I can play with IR + 433MHz + RGB LED strips using official Arduino board.
Don’t hesitate to reply me if there is an easier solution :wink:
@Neoxelox Is it better for you ?
Ben
