Part 2 of Many DHT11 and some Math
Was working but now, I get
Disconnected with result code 1
Connected with result code 0
SUB v1/da9e1390-e819-11e9-8221-599f77add412/things/11c78520-f5cd-11e9-a38a-d57172a4b4d4/cmd/+
PUB v1/da9e1390-e819-11e9-8221-599f77add412/things/11c78520-f5cd-11e9-a38a-d57172a4b4d4/sys/model Python
PUB v1/da9e1390-e819-11e9-8221-599f77add412/things/11c78520-f5cd-11e9-a38a-d57172a4b4d4/sys/version 1.1.0
PUB v1/da9e1390-e819-11e9-8221-599f77add412/things/11c78520-f5cd-11e9-a38a-d57172a4b4d4/data/1 temp,c=13
PUB v1/da9e1390-e819-11e9-8221-599f77add412/things/11c78520-f5cd-11e9-a38a-d57172a4b4d4/data/2 lum,lux=130
PUB v1/da9e1390-e819-11e9-8221-599f77add412/things/11c78520-f5cd-11e9-a38a-d57172a4b4d4/data/3 bp,hpa=813
Caught exception in on_connect: Connection failed, not authorized
Disconnected with result code 5
Ok I deleted my origional sensor widger and added a new widget for the example. Working again now
great. now try this code and see if you get DHt reading:
ok working, humidity is way off but the sensor works…
Temp=22.0*C Humidity=17.0%
now combine both the codes:
#!/usr/bin/env python
import cayenne.client
import time
import logging
import Adafruit_DHT
MQTT_USERNAME  = "xxx"
MQTT_PASSWORD  = "xxxx"
MQTT_CLIENT_ID = "xxx"
sensor = Adafruit_DHT.DHT11
pin = 23
def on_message(message):
client.begin(MQTT_USERNAME, MQTT_PASSWORD, MQTT_CLIENT_ID, loglevel=logging.INFO)
i=0
timestamp = 0
while True:
client.loop()
humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
    client.virtualWrite(3, 10, "temp", "c" )
        if temp11 is not None:
            client.virtualWrite(1, temp11, "temp", "c" )
        else:
            print("temp error")
        if humidity11 is not None:
            client.virtualWrite(2, humidity11, "rel_hum", "p")
        else:
            print("humidity error")
    timestamp = time.time()
    i = i+1
the final code works for me:
import time
import logging
import math
import Adafruit_DHT
MQTT_USERNAME  = "xxxx"
pin = 18
i=0
timestamp = 0
while True:
    client.loop()
    humidity11, temp11 = Adafruit_DHT.read_retry(sensor, pin)
#    client.virtualWrite(1, temp11, "temp", "c" )
        client.virtualWrite(1, 10, "temp", "c" )
        else:
            print("temp error")
        else:
        if temp11 is not None and humidity11 is not None:
            VPDME=((6.1078*math.exp(17.08085*temp11/(234.175+temp11)))-(6.1078*math.exp(17.08085*temp11/(234.175+temp11))*(humidity11/100)))/10.
            print(VPDME)
            client.virtualWrite(2, humidity11, "pressure", "kpa")
        else:
            print("VPDME error")
        i = i+1
Quick Question:
I see both the temp and timer is writing the channel 1:
Also, the next to statements are also writing to the same channel:
        else:
            print(VPDME)
Is it safe to say I can leave the first if as is and change the humidity and vpdme to:
        else:
            print(VPDME)
            client.virtualWrite(3, VPDME, "pressure", "kpa")
I get this traceback when I run the script:
File “shramik.py”, line 25, in
TypeError: begin() got an unexpected keyword argument ‘loglevel’
how is that possible. you said it was working previously. Can you just copy and paste code from combine code to the code that was working.
it is not included in the code, it is commented.
Sorry, my bad. You need to use a different channel numbers for each widget and change humidity and vpdme.
Ill run through the last code again and let you know in a moment.
Ok so what I found was"
running script with sudo python shramik.py i get (same without sudo)
File “shramik.py”, line 24, in
running script with sudo python3 shramik.py i get:
File “shramik.py”, line 6, in
import Adafruit_DHT
ImportError: No module named ‘Adafruit_DHT’
running sudo python3 Example-03-CayenneClient.py works perfectly no issues.
adafruit/Adafruit_Python_DHT/blob/master/examples/simpletest.py Also works perfectly
Another difference is that I am running the two scripts from different location, one is in /home/pi/python/ and the other is /home/pi/Cayenne-MQTT-Python
more info:
pi@Bettie-Pi:~ $ python
Python 2.7.13 (default, Sep 26 2018, 18:42:22)
[GCC 6.3.0 20170516] on linux2
Type “help”, “copyright”, “credits” or “license” for more information.
maybe something to do with the shebang #!/usr/bin/env python ?
try sudo pip3 install Adafruit_DHT and then run sudo python3 shramik.py
Do I run that command in the existing Adafruit folder ? Also, I see my version of python is 2.7 will the python3 command worlk ?
if this works then?? you can run it anywhere you want.
Thanks for the help I really do appreciate it, just frustrating that the seperaly the work perfectly but combined there is a issue.
did you try this?
Not yet, will try when I get home from work work. Will let you know.
