Virtual numeric keypad
HI Shramik. I tried the code (the one I asked you if it will work). For reasons that I don’t know it didn’t work. Dunno what I’ve been doin’ wrong. I thought of another approach and this time I will use the status of the widget (whether it’s on or off) in my if statement.
char username[] = "";
char password[] = "";
char clientID[] = "";
#define VIRTUAL_CHANNEL_2 2
#define ACTUATOR_PIN_2 2
#define VIRTUAL_CHANNEL_3 3
#define ACTUATOR_PIN_3 3
#define VIRTUAL_CHANNEL_4 4
#define ACTUATOR_PIN_4 4
#define VIRTUAL_CHANNEL_5 5
#define ACTUATOR_PIN_5 5
#define VIRTUAL_CHANNEL_6 6
#define ACTUATOR_PIN_6 6
#define VIRTUAL_CHANNEL_7 7
#define ACTUATOR_PIN_7 7
#define VIRTUAL_CHANNEL_8 8
#define ACTUATOR_PIN_8 8
#define VIRTUAL_CHANNEL_9 9
#define ACTUATOR_PIN_9 9
  pinMode(ACTUATOR_PIN_2, OUTPUT);
  pinMode(ACTUATOR_PIN_3, OUTPUT);
  pinMode(ACTUATOR_PIN_4, OUTPUT);
  pinMode(ACTUATOR_PIN_5, OUTPUT);
  pinMode(ACTUATOR_PIN_6, OUTPUT);
  pinMode(ACTUATOR_PIN_7, OUTPUT);
  pinMode(ACTUATOR_PIN_8, OUTPUT);
  pinMode(ACTUATOR_PIN_9, OUTPUT);
  pinMode(13, LOW);
if (VIRTUAL_CHANNEL_2 == HIGH &&
    VIRTUAL_CHANNEL_3 == HIGH &&
    VIRTUAL_CHANNEL_4 == HIGH &&
    VIRTUAL_CHANNEL_5 == HIGH &&
    VIRTUAL_CHANNEL_6 == LOW &&
    VIRTUAL_CHANNEL_7 == LOW &&
    VIRTUAL_CHANNEL_8 == LOW &&
    VIRTUAL_CHANNEL_9 == LOW)
    digitalWrite(13,HIGH);
else
    digitalWrite(13,LOW);
// This function is for button 2.
CAYENNE_IN(2)
  int value = getValue.asInt();
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_2, ACTUATOR_PIN_2, value);
  digitalWrite(ACTUATOR_PIN_2, value);
// This function is for button 3.
CAYENNE_IN(3)
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_3, ACTUATOR_PIN_3, value);
  digitalWrite(ACTUATOR_PIN_3, value);
// This function is for button 4.
CAYENNE_IN(4)
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_4, ACTUATOR_PIN_4, value);
  digitalWrite(ACTUATOR_PIN_4, value);
// This function is for button 5.
CAYENNE_IN(5)
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_5, ACTUATOR_PIN_5, value);
  digitalWrite(ACTUATOR_PIN_5, value);
// This function is for button 6
CAYENNE_IN(6)
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_6, ACTUATOR_PIN_6, value);
  digitalWrite(ACTUATOR_PIN_6, value);
// This function is for button 7.
CAYENNE_IN(7)
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_7, ACTUATOR_PIN_7, value);
  digitalWrite(ACTUATOR_PIN_7, value);
// This function is for button 8.
CAYENNE_IN(8)
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_8, ACTUATOR_PIN_8, value);
  digitalWrite(ACTUATOR_PIN_8, value);
// This function is for button 9.
CAYENNE_IN(9)
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_9, ACTUATOR_PIN_9, value);
  digitalWrite(ACTUATOR_PIN_9, value);
What do u think? Will this one work?
Try this code:
char username[] = "0";
char clientID[] = "d";
  pinMode(13, LOW);
int s;
int t;
int u;
int v;
int w;
int x;
int y;
int z;
if ((s == 1) &&
    (t == 1) &&
    (u == 1) &&
    (v == 1) &&
    (w == 0) &&
    (x == 0) &&
    (y == 0) &&
    (z == 0))
else
CAYENNE_IN(2)
  s = getValue.asInt();
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_2, ACTUATOR_PIN_2, s);
  digitalWrite(ACTUATOR_PIN_2, s);
CAYENNE_IN(3)
 t = getValue.asInt();
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_3, ACTUATOR_PIN_3, t);
  digitalWrite(ACTUATOR_PIN_3, t);
CAYENNE_IN(4)
  u = getValue.asInt();
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_4, ACTUATOR_PIN_4, u);
  digitalWrite(ACTUATOR_PIN_4, u);
CAYENNE_IN(5)
  v = getValue.asInt();
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_5, ACTUATOR_PIN_5, v);
  digitalWrite(ACTUATOR_PIN_5, v);
CAYENNE_IN(6)
  w = getValue.asInt();
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_6, ACTUATOR_PIN_6, w);
  digitalWrite(ACTUATOR_PIN_6, w);
CAYENNE_IN(7)
   x = getValue.asInt();
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_7, ACTUATOR_PIN_7, x);
  digitalWrite(ACTUATOR_PIN_7, x);
CAYENNE_IN(8)
  y = getValue.asInt();
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_8, ACTUATOR_PIN_8, y);
  digitalWrite(ACTUATOR_PIN_8, y);
CAYENNE_IN(9)
  z = getValue.asInt();
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_9, ACTUATOR_PIN_9, z);
  digitalWrite(ACTUATOR_PIN_9, z);
what’s changed Shramik?
Does it work?
yes Shramik but I wonder what was changed? Is it the same code I have posted or you made some changes
if it works i guess you can compare and check what was the mistake :wink:
nonetheless thank u buddy as always
I found the mistake! What a difference a small mistake makes! Learning lesson for me
