the script is independent of the pi agent version and should work without any issue.
It does not work actually and on the Arduino tab, I get a message that I have to update the agent. Also this file is no longer available for download from the github repository.
you will need to add a new device now as the old cayenne Arduino has been discontinued. you also have to use the new MQTT library GitHub - myDevicesIoT/Cayenne-MQTT-Arduino: Cayenne MQTT Arduino Library
I need to add the Arduino to Raspberry Pi. Is there somewhere a step by step how to add this library to Raspberry Pi ?
Thank you.
steps:
- clone the directory on your pi
sudo git clone https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino.git
2 . navigate to scripts folders.
3 . make it executablesudo chmod +x cayenne-ser.sh
4 . run the scripts./cayenne-ser.sh -c /dev/ttyACM0 -b 9600 -s mqtt.mydevices.com -p 1883
