Bug Filed on 02-25-2016: Install fails in Installing myDevices agent
That doesn’t look like the default paritioning, did you change it? It should look similar to this:
`pi@raspberrypi:~ $ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       7.2G  3.4G  3.5G  49% /
devtmpfs        459M     0  459M   0% /dev
tmpfs           463M     0  463M   0% /dev/shm
tmpfs           463M  6.3M  457M   2% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           463M     0  463M   0% /sys/fs/cgroup
/dev/mmcblk0p1   60M   20M   41M  34% /boot
tmpfs            93M     0   93M   0% /run/user/1000`
Regardless, /dev, /net, /home, and /Volumes/boot are 100% full and that’s more than likely what is causing your problem.
