Cant connect to cayenne
I want to connect my Arduino UNO with Ethernet sheild to Cayenne. I’m using windows 7. but it cant connect. what can i do?
Regards,
Ahmed
Hi @elngar_7,
Could you show us which sketch file you are using, and the output from your Arduino IDE serial monitor when attempting to connect?
Thanks for your reply. here is the sketch i used
Cayenne Ethernet Example
This sketch connects to the Cayenne server using an Arduino Ethernet Shield W5100
Steps:
#include <CayenneEthernet.h
char token = “----------------”;
Cayenne.begin(token);
Also, Here is the output from Arduino serial monitor:
[0] MAC: FE-B1-6B-D4-CD-AD
[0] Getting IP…
[60445] DHCP Failed!
[1] Getting IP…
[60446] DHCP Failed!
[1] MAC: FE-B1-6B-D4-CD-AD
[1] Getting IP…
Regards
I see now, that DHCP Failed message means that your Arduino is unable to receive an IP address from the router on your network. I made up a big post of reasons that we’ve run into where users have seen this error some time ago. I’d start there and step through each of these issues to rule them out or see if they help.
