Delete triggers IOS?
Rpi 3 / IOS. (Still using webiopi old “manual” version Rpi3)
Unable to delete triggers.
/Sam
Welcome to the Cayenne Community, @sm5uiu
We could probably improve the UI on this – you need to drag on the bottom part of the trigger to reveal the delete button. Here is a picture with me beginning to reveal the delete button:
