Esp8266-12e MQTT sketch wont compile
What am I missing here? I have imported the Cayenne-MQTT-ESP-master library and installed the board.
Arduino IDE 1.8.4
board NodeMCU 1.0 (ESP-12E Module)
Documents\Arduino\libraries\Cayenne-MQTT-ESP-master\src/CayenneArduinoMQTTClient.h:45:7: note: no known conversion for argument 1 from ‘WiFiClient’ to ‘int&’
exit status 1
#include <CayenneArduinoDefines.h>
#include <CayenneArduinoMQTTClient.h>
#include <CayenneHandlers.h>
#include <CayenneMessage.h>
#include <CayenneMQTTESP32.h>
#include <CayenneMQTTWiFiClient.h>
#include <DetectDevice.h>
//#define CAYENNE_DEBUG
char ssid[] = "obnoxious";
char wifiPassword[] = "*";
char username[] = "*";
char password[] = "*";
char clientID[] = "*";
unsigned long lastMillis = 0;
CAYENNE_OUT_DEFAULT()
	//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
follow this tutorial Adding a New Device using MQTT
remove all this :
and keep only :
Thank you.
