Esp8266 : it constantly lose connection (help me)
esp8266 : it constantly lose connection
How to fix it?
help me
code:
#include "CayenneDefines.h"
char token[] = "";
char ssid[] = "";
char password[] = "";
  pinMode(0, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(2, OUTPUT);
  Serial.begin(115200);
// This function will be called every time a Dashboard widget writes a value to Virtual Pin 2.
CAYENNE_IN(V0)
  CAYENNE_LOG("Got a value: %s", getValue.asStr());
  int i1 = getValue.asInt();
  int i11 = map(i1,0,102300,0,1023);
  Serial.print("PWM:");
  Serial.println(i11);
   analogWrite(0,i11);
CAYENNE_OUT(V1)
  Cayenne.virtualWrite(V1,GiaTriDoAm);
CAYENNE_IN(V2)
  int i = getValue.asInt();
  if (i == 0)
    digitalWrite(4, LOW);
  else
    digitalWrite(4, HIGH);
CAYENNE_IN(V3)
  if (i == 0)
    digitalWrite(5, LOW);
  else
    digitalWrite(5, HIGH);
CAYENNE_IN(V4)
  if (i == 0)
    digitalWrite(2, LOW);
  else
    digitalWrite(2, HIGH);
I am having similar problem using the ESP8266 boards, I think the BlynkSimple library has a bug that causes the WDT timer to reset
other iot platforms that do not use the Blynk library work OK
I hope it gets fixed when Cayenne supports the ESP8266 officially.
The Esp8266 is working for me-
I’m using an Esp12-e, and the Arduino IDE.
I put the ESP into “program” mode by
shorting GPIO 0 to ground for 20 seconds while booting.
Then you can upload your arduino code-
This code works for me-
the rest of the programming is done
from the App or the Cayenne HTML page.
char token[] = "YourToken";
char ssid[] = "YourSSID";
char password[] = "YourPassword";
I don’t see any resets in his screen shot there. I think this may be another issue such as 2.4GHz interference (or too far from access point) or low quality WAN causing disconnects.
