Hi
I’m using an arduino uno in combination with an ESP8266-01 module to connect to Cayenne. With the code below, the ESP does in fact connect to Cayenne, but every minute or so, it disconnects.
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
Serial.begin(115200);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
If I take a look in the serial monitor, the following shows up:
15:33:47.619 → AT+CIPSEND=1,40
15:33:52.648 → AT+CIPSEND=1,40
15:33:57.643 → AT+CIPSEND=1,40
15:34:02.661 → AT+CIPSEND=1,40
15:34:17.673 → AT+CIPSEND=1,40
15:34:32.526 → AT+CIPSEND=1,2
15:34:37.524 → AT+CIPSEND=1,2
15:34:42.556 → AT+CIPCLOSE=1
15:34:47.550 → [639025] Disconnected
When the ESP is disconnected, a new connection is established and the above repeats itself.
I’m totally new to arduino and Cayenne, so I have no idea what I’m talking about, but does anybody know how to fix this?
Help would be grately appreciated!
Kind regards
if you read the into for this code it mentions that this code is not suited for Arduino and won’t be stable.
Anything you would recommend instead?
you can use software serial.
#include <SoftwareSerial.h>
#define VIRTUAL_CHANNEL 1
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
SoftwareSerial EspSerial(2,3);
//Serial.begin(9600);
//delay(10);
EspSerial.begin(9600);
delay(10);
Serial.println("connecting to wifi");
WiFi.begin(ssid, wifiPassword);
Serial.println("connected to wifi");
if (WiFi.status() == WL_CONNECTED) {
Serial.println("disconnect to wifi");
WiFi.disconnect();
Serial.println("disconnected");
Serial.println("connecting to cayenne");
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
though this is also not stable, but give it a try,
I get a bunch of error messages, including " ‘WiFi’ was not declared in this scope"…
Maybe a change in hardware is a better idea?
ohh, remove all the wifi parts.
Now I get this as an error:
no matching function for call to ‘CayenneMQTTESP8266Client::begin(char [37], char [41], char [37], char [14], char [11])’
use this one:
char ssid[] = "AP-E16C00";
char wifiPassword[] = "mydevices@gemtek";
SoftwareSerial mySerial(10, 11);
#define EspSerial mySerial
delay(10);
delay(10);
I’ve uploaded your code without errors, but the serial monitor doesn’t show anything… Cayenne also says that the arduino is offline.
Still nothing I’m afraid…
Haha, woops, didn’t even saw it myself
Now the serial monitor does something, but it still doesn’t connect correctly.
If I check at 9600 baud, it says:
“Failed to enable MUX”
“Failed to set STA mode”
And occasionally “Failed to disable Echo”
Btw, just to be sure: I connected the RX of the ESP to pin 11(TX of Arduino) and the TX of the ESP to pin 10 (RX of Arduino), correct?
With the hardware serial, I had to upload the sketch first and then connect the wires, is that necessary here?
i hope you are using a voltage divider.
I am not actually, some posts online said that it would’nt be a problem… Could that in fact be it?
it is always better to be on the safer side.
But that still won’t fix my code I’m afraid
Could it be that the Uno provides insufficient power for the ESP?
let’s test it out whether the esp is working and we can communicate with it. upload this code and send AT and see if esp send okay response.
// Basic serial communication with ESP8266
// Uses serial monitor for communication with ESP8266
// Pins
// Arduino pin 2 (RX) to ESP8266 TX
// Arduino pin 3 to voltage divider then to ESP8266 RX
// Connect GND from the Arduiono to GND on the ESP8266
// Pull ESP8266 CH_PD HIGH
// When a command is entered in to the serial monitor on the computer
// the Arduino will relay it to the ESP8266
//AT+CIOBAUD=9600
//AT+IPR=9600
SoftwareSerial ESPserial(10, 11); // RX | TX
//AT+CIOBAUD=9600
Serial.begin(9600); // communication with the host computer
//while (!Serial) { ; }
// Start the software serial for communication with the ESP8266
ESPserial.begin(115200);
Serial.println("");
Serial.println("Remember to to set Both NL & CR in the serial monitor.");
Serial.println("Ready");
Serial.println("");
// listen for communication from the ESP8266 and then write it to the serial monitor
if ( ESPserial.available() ) { Serial.write( ESPserial.read() ); }
// listen for user input and send it to the ESP8266
if ( Serial.available() ) { ESPserial.write( Serial.read() ); }
