Enjoying this setup currently
#include "CayenneDefines.h"
#include "BlynkSimpleEsp8266.h"
#include "CayenneWiFiClient.h"
#include "ESP8266WiFi.h"
char token[] = "yourtoken";
// Your network name and password.
char ssid[] = "yourssid";
char password[] = "yourpassword";
// initialize digital pin 2 as an output.
pinMode(16, OUTPUT);
pinMode(5, OUTPUT);
pinMode(D2, OUTPUT);
pinMode(D3, OUTPUT);
pinMode(D4, OUTPUT);
pinMode(D5, OUTPUT);
pinMode(D6, OUTPUT);
pinMode(D7, OUTPUT);
Cayenne.begin(token, ssid, password);
// This function will be called every time a Dashboard widget writes a value to Virtual Pin 2.
CAYENNE_IN(V0)
CAYENNE_LOG("Got a value: %s", getValue.asStr());
int i = getValue.asInt();
if (i == 0)
digitalWrite(D0, HIGH);
digitalWrite(D0, LOW);
CAYENNE_IN(V1)
if (i == 0)
digitalWrite(D1, HIGH);
digitalWrite(D1, LOW);
CAYENNE_IN(V2)
if (i == 0)
digitalWrite(D2, HIGH);
digitalWrite(D2, LOW);
CAYENNE_IN(V3)
if (i == 0)
digitalWrite(D3, HIGH);
digitalWrite(D3, LOW);
CAYENNE_IN(V4)
if (i == 0)
digitalWrite(D4, HIGH);
digitalWrite(D4, LOW);
CAYENNE_IN(V5)
if (i == 0)
digitalWrite(D5, HIGH);
digitalWrite(D5, LOW);
CAYENNE_IN(V6)
if (i == 0)
digitalWrite(D6, HIGH);
digitalWrite(D6, LOW);
CAYENNE_IN(V7)
if (i == 0)
digitalWrite(D7, HIGH);
digitalWrite(D7, LOW);
