Relay control based on temperature (using ESP8266 and Cayenne)
I want to control a relay based on temperature, using ESP8266 and Cayenne.
Can you help me how to do that?
Waiting for your response.
Regards,
Fatmir Prekupi
have you tried connecting your esp to cayenne? Have a look at the example folder to get the all the required codes Cayenne-MQTT-Arduino/examples at master ยท myDevicesIoT/Cayenne-MQTT-Arduino ยท GitHub
I need to control a relay using NODEMCU ESP8266 and CAYENNE.
These codes are for Arduino and Cayenne.
What do i need to change to use these codes for NODEMCU ESO8266 ?
Dear,
I have tried to control a relay through Cayenne and ESP8266, but i have a problem.
I cant add a relay widget on Cayenne (I cant choose a device).
Why is happening this, can you help me ?
Delete the previous device from cayenne dashboard and follow this step:-
  1. Add a new device by following these steps:- add new ----> device/widget ---->microcontroller โ€”> arduino ----> next โ€”> you will get MQTT credentials.
  2. Add the credentials in below code:-
Code
This example shows how to connect to Cayenne using an ESP8266 and send/receive sample data.
Steps:
1. If you have not already installed the ESP8266 Board Package install it using the instructions here: https://github.com/esp8266/Arduino#installing-with-boards-manager.
2. Select your ESP8266 board from the Tools menu.
//#define CAYENNE_DEBUG
char ssid[] = "ssid";
#define VIRTUAL_CHANNEL 1
#define ACTUATOR_PIN 4
CAYENNE_OUT_DEFAULT()
	//Cayenne.luxWrite(2, 700);
CAYENNE_IN(VIRTUAL_CHANNEL)
	int value = getValue.asInt();
	CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
  1. Add the green widget to your dashboard.
  2. Navigate to Add new ----> Device/Widgets โ€”> Actuator ----> Generic -----> Digital Output โ€”> Fill all details with channel 1 select and click add.
Thanks for the code. I have used this code and its correct. I have added the widget in dashboard but cant change the state of relay.
Do you know why is happening this, can you help me to solve this problem ?
add this in your code and see what do you get in the serial monitor when you press the button.
This is what i get in serial monitor:
23:29:40.582 โ†’ [35770] Connection ok
23:29:41.597 โ†’ [36784] Publish: topic 1, channel 0, value 36784, subkey , key
23:29:48.806 โ†’ [44006] Message received: topic 2, channel 1
23:29:48.874 โ†’ [44006] In: value 1, channel 1
23:29:48.907 โ†’ [44006] Channel 1, pin 4, value 1
23:29:48.942 โ†’ [44006] publishState: topic 1 channel 1
23:29:48.976 โ†’ [44034] Publish: topic 1, channel 1, value 1, subkey , key
23:29:49.044 โ†’ [44098] Send response: 3CIF4zp7nMsFw2y
23:29:50.736 โ†’ [45926] Connection ok
23:29:55.774 โ†’ [50975] Message received: topic 2, channel 1
23:29:55.842 โ†’ [50975] In: value 0, channel 1
23:29:55.875 โ†’ [50975] Channel 1, pin 4, value 0
23:29:55.909 โ†’ [50976] publishState: topic 1 channel 1
23:29:55.943 โ†’ [51003] Publish: topic 1, channel 1, value 0, subkey , key
23:29:56.011 โ†’ [51067] Send response: qrDtJILLvLqEDzL
23:29:57.331 โ†’ [52524] Publish: topic 1, channel 0, value 52524, subkey , key
23:30:01.422 โ†’ [56600] Connection ok
23:30:11.595 โ†’ [66787] Connection ok
23:30:12.614 โ†’ [67802] Publish: topic 1, channel 0, value 67801, subkey , key
23:30:21.779 โ†’ [76967] Connection ok
Can you tell me why i cant control the relay through Cayenne ?
Dear shramik_salgaonkar,
Now everything is ok, i can control the relay. I just changed the pin, now i am using pin 14 and with the same code.
Thanks.
