Hi again! This time I will make a tutorial in an actual programming language, Java.
Well, my code can look like a little tricky and complicated, but I didn’t wanted to use any external library, so this tutorial will be in vanilla Java, except for JSON library, you can make your own json parser, but you know im lazy. Making REST API calls would be easier with libraries like apache and gson to parse…
Hope you like it! (PD: Im not a Java expert so my code can be improved a lot, and I know there are lots of variables that you really don’t need, but I extracted the code directly from one of my projects.
LIBRARIES
import java.io.ByteArrayOutputStream;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.net.HttpURLConnection;
import java.net.URL;
import java.net.URLConnection;
import java.nio.charset.StandardCharsets;
import org.json.JSONObject;
(OPTIONAL)
GETTING AUTH TOKEN [POST]
Firstly, if we want to make any API call we need an auth token, which will be granted if we make a post call with our credentials.
URL: https://auth.mydevices.com/oauth/token
HEADERS: content-type
value application/json
BODY: {"grant_type":"password","email":"YOUR EMAIL","password":"YOUR PASSWORD"}
This are our global variables:
public static final String AUTH_URL = "https://auth.mydevices.com/oauth/token";
public static final String AUTH_HEADER = "content-type";
public static final String AUTH_HEADER_VALUE = "application/json; charset=UTF-8";
public static final String AUTH_HELPER1 = "{\"grant_type\":\"password\",\"email\":\"";
public String cayenneEmail = "";
public static final String AUTH_HELPER2 = "\",\"password\":\"";
public String cayennePass = "";
public static final String AUTH_HELPER3 = "\"}";
The code:
String bodyConstructor = AUTH_HELPER1 + cayenneEmail + AUTH_HELPER2 + cayennePass + AUTH_HELPER3; //Makes the POST BODY
String rawToken = "";
try {
URL url = new URL(AUTH_URL); //Creates and url object
URLConnection con = url.openConnection();
HttpURLConnection http = (HttpURLConnection)con; //Creates HttpURLConnection object from URL Object
http.setRequestMethod("POST"); //Sets the method: POST, GET, PUT...
http.setDoOutput(true); //Sets that we are sending a Body with the request
byte[] out = bodyConstructor .getBytes(StandardCharsets.UTF_8);
int length = out.length;
http.setFixedLengthStreamingMode(length);
http.setRequestProperty(AUTH_HEADER, AUTH_HEADER_VALUE); //Sets Headers
http.connect(); //Connects
try {
OutputStream os = http.getOutputStream();
os.write(out); //Writes Body
} catch (Exception e) {
//Do something
rawToken = parseResponse(http.getInputStream(), "UTF-8"); //Parses the response
http.disconnect(); //Disconnects
JSONObject obj = new JSONObject(rawToken); //Creates a JSONObject Object
rawToken = obj.getString("access_token"); //Finds Auth Token with access_token tag
//Do something
FUNCTION TO PARSE THE RESPONSE
PD: is not mine, i just googled how to parse InputStream responses (I have to learn more Java hehe).
public static String parseResponse(InputStream inputStream, String encoding) throws IOException {
return readFully(inputStream).toString(encoding);
public static ByteArrayOutputStream readFully(InputStream inputStream) throws IOException {
ByteArrayOutputStream baos = new ByteArrayOutputStream();
byte[] buffer = new byte[1024];
int length = 0;
while ((length = inputStream.read(buffer)) != -1) {
baos.write(buffer, 0, length);
return baos;
GETTING SENSOR DATA [GET]
To get sensor’s data we need the Auth Token we got before and send a GET request to the API.
URL: https://platform.mydevices.com/v1.1/telemetry/DEVICE ID/sensors/SENSOR ID/summaries?type=latest
HEADERS: Authorization
value Bearer AUTHTOKEN
public static final String DATA_URL = "https://platform.mydevices.com/v1.1/telemetry/";
public static final String DATA_HELPER1 = "/sensors/";
public static final String DATA_HELPER2 = "/summaries?type=";
public String DATA_SUMMARYTYPE = "latest";
public static final String DATA_HEADER = "Authorization";
public String DATA_HEADER_VALUE = "Bearer ";
public String deviceID = "";
public String sensorID = "";
public String authToken = "";
The code: (The explanation of code is the same as you saw before)
String urlConstructor = DATA_URL + deviceID + DATA_HELPER1 + sensorID + DATA_HELPER2 + DATA_SUMMARYTYPE;
DATA_HEADER_VALUE = "Bearer " + authToken;
String rawValue = "";
try {
URL url2 = new URL(urlConstructor);
URLConnection con2 = url2.openConnection();
HttpURLConnection http2 = (HttpURLConnection)con2;
http2.setRequestMethod("GET");
http2.setRequestProperty(DATA_HEADER, DATA_HEADER_VALUE);
http2.connect();
try {
rawValue = parseResponse2(http2.getInputStream(), "UTF-8");
rawValue = rawValue.replace("[",""); //Just removing things to correctly parse the JSON
rawValue = rawValue.replace("]","");
JSONObject obj2 = new JSONObject(rawValue);
http2.disconnect();
rawValue = obj2.getString("v"); //Finds the sensor's value with v tag
//Do something
//Do something
The Function to parse the response is the same as before
SENDING DATA TO CAYENNE DASHBOARD / CONTROLLING AN ACTUATOR [POST]
To send data or cotrol an actuator you need the Auth Token we got before and send a POST request to the API.
URL: https://platform.mydevices.com/v1.1/things/DEVICE ID/cmd
and content-type
value application/json; charset=UTF-8
BODY: {"channel":CHANNEL,"value":VALUE}
public static final String ACTU_URL = "https://platform.mydevices.com/v1.1/things/";
public static final String ACTU_HELPER1 = "/cmd";
public static final String BODY_ACTU_HELPER1 = "{\"channel\":";
public static final String BODY_ACTU_HELPER2 = ",\"value\":";
public static final String BODY_ACTU_HELPER3 = "}";
public static final String ACTU_HEADER = "Authorization";
public String ACTU_HEADER_VALUE = "Bearer ";
public static final String ACTU_HEADER2 = "content-type";
public static final String ACTU_HEADER_VALUE2 = "application/json; charset=UTF-8";
String ACTU_bodyConstructor = BODY_ACTU_HELPER1 + Channel + BODY_ACTU_HELPER2 + Value + BODY_ACTU_HELPER3; //Makes the POST BODY
String ACTU_urlConstructor = ACTU_URL + DeviceID + ACTU_HELPER1;
ACTU_HEADER_VALUE = "Bearer " + AuthToken;
String rawConfirm = "";
try {
URL url3 = new URL(ACTU_urlConstructor);
URLConnection con3 = url3.openConnection();
HttpURLConnection http3 = (HttpURLConnection)con3;
http3.setRequestMethod("POST");
http3.setDoOutput(true);
byte[] out3 = ACTU_bodyConstructor .getBytes(StandardCharsets.UTF_8);
int length3 = out3.length;
http3.setFixedLengthStreamingMode(length3);
http3.setRequestProperty(ACTU_HEADER, ACTU_HEADER_VALUE);
http3.setRequestProperty(ACTU_HEADER2, ACTU_HEADER_VALUE2);
http3.connect();
try {
OutputStream os3 = http3.getOutputStream();
os3.write(out3);
controlActuatorConfirm("[POST]ERROR WRITING DATA! : " + e);
rawConfirm = parseResponse(http3.getInputStream(), "UTF-8");
http3.disconnect();
JSONObject obj3 = new JSONObject(rawConfirm);
rawConfirm = obj3.getString("success"); //Finds the success variable with success tag
//Do something
