MQTT events and triggers
Can you use sensor information to create events and triggers via mqtt? cant seem to make it work with it st all.
You can create triggers based on MQTT widgets the same as any other widget: Go to Add New > Trigger, drag your MQTT-connected device from the left sidebar into the ‘IF’ box, then a drop down menu should appear with options for each of your widgets.
Scheduling is not yet implemented for MQTT-connected devices, so if you try to create an event, you won’t see that device as an option in the device list.
nice
