Hi Guys,
I went through the steps to install the software on my pi but the first visit page is stuck on rebooting pi.
I rebooted several time but its still stuck… is there anywhere to look for troubleshooting tips???
Hi Guys,
How long did you wait before you manually rebooted? The entire install can take 5-10 minutes the first time, so if you manually rebooted you may have interrupted it. Try just running the install script again to see if that gets it back online.
re-ran the script. it went through it complete process and rebooted…
The first visit page still on rebooting device. The Pi has rebooted on its own…
Are you using the terminal to install, or one of the smartphone apps? If you are using a smartphone app, which one?
using command line. Here is ps output:
pi@tecsud-pi ~ $ ps axg
PID TTY STAT TIME COMMAND
1 ? Ss 0:01 init [2]
2 ? S 0:00 [kthreadd]
3 ? S 0:01 [ksoftirqd/0]
5 ? S< 0:00 [kworker/0:0H]
7 ? S< 0:00 [khelper]
8 ? S 0:00 [kdevtmpfs]
9 ? S< 0:00 [netns]
10 ? S< 0:00 [perf]
11 ? S 0:00 [khungtaskd]
12 ? S< 0:00 [writeback]
13 ? S< 0:00 [crypto]
14 ? S< 0:00 [bioset]
15 ? S< 0:00 [kblockd]
16 ? S 0:01 [kworker/0:1]
17 ? S< 0:00 [rpciod]
18 ? S 0:00 [kswapd0]
19 ? S 0:00 [fsnotify_mark]
20 ? S< 0:00 [nfsiod]
26 ? S< 0:00 [kthrotld]
27 ? S< 0:00 [VCHIQ-0]
28 ? S< 0:00 [VCHIQr-0]
29 ? S< 0:00 [VCHIQs-0]
30 ? S< 0:00 [iscsi_eh]
31 ? S< 0:00 [dwc_otg]
32 ? S< 0:00 [DWC Notificatio]
34 ? S 0:00 [VCHIQka-0]
35 ? S< 0:00 [SMIO]
36 ? S< 0:00 [deferwq]
39 ? S 0:00 [mmcqd/0]
40 ? S 0:00 [scsi_eh_0]
41 ? S< 0:00 [scsi_tmf_0]
42 ? S 0:01 [usb-storage]
43 ? S 0:00 [jbd2/sda1-8]
44 ? S< 0:00 [ext4-rsv-conver]
159 ? Ss 0:00 udevd --daemon
260 ? S 2:07 [w1_bus_master1]
301 ? S 0:00 udevd --daemon
307 ? S 0:00 udevd --daemon
354 ? S 0:00 [spi0]
389 ? S< 0:00 [kworker/0:1H]
1601 ? S 0:01 /usr/sbin/ifplugd -i eth0 -q -f -u0 -d10 -w -I
1608 ? S 0:00 /usr/sbin/ifplugd -i lo -q -f -u0 -d10 -w -I
2033 ? S< 0:00 [cfg80211]
2106 ? Sl 0:00 /usr/sbin/rsyslogd -c5
2182 ? Ss 0:00 /sbin/dhcpcd
2201 ? Ss 0:00 /usr/sbin/apache2 -k start
2244 ? Ss 0:00 /usr/sbin/cron
2261 ? S 0:00 /usr/sbin/apache2 -k start
2262 ? S 0:00 /usr/sbin/apache2 -k start
2266 ? S 0:00 /usr/sbin/apache2 -k start
2267 ? S 0:00 /usr/sbin/apache2 -k start
2269 ? S 0:00 /usr/sbin/apache2 -k start
2294 ? Ss 0:00 /usr/bin/dbus-daemon --system
2324 ? S 0:00 avahi-daemon: running [tecsud-pi.local]
2325 ? S 0:00 avahi-daemon: chroot helper
2387 ? Ss 0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 104:107
2396 ? S 0:00 /bin/sh /usr/bin/mysqld_safe
2489 ? S 0:01 /usr/sbin/snmpd -Lsd -Lf /dev/null -u snmp -g snmp -I -smux -p /var/run/snmpd.pid
2647 ? Ss 0:00 /usr/sbin/sshd
2803 ? Sl 0:07 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --pid-file=/var/run/mysqld/my
2804 ? S 0:00 logger -t mysqld -p daemon.error
2827 ? Ss 0:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers.d/ --socket /var/run/thd.socket --pidfile /var/run/thd.pid --user nobody
2974 tty1 Ss+ 0:00 /sbin/getty --noclear 38400 tty1
2975 tty2 Ss+ 0:00 /sbin/getty 38400 tty2
2976 tty3 Ss+ 0:00 /sbin/getty 38400 tty3
2977 tty4 Ss+ 0:00 /sbin/getty 38400 tty4
2978 tty5 Ss+ 0:00 /sbin/getty 38400 tty5
2979 tty6 Ss+ 0:00 /sbin/getty 38400 tty6
2980 ? Ss+ 0:00 /sbin/getty -L ttyAMA0 115200 vt100
3153 ? Ss 0:00 sshd: pi [priv]
3157 ? S 0:00 sshd: pi@pts/0
3158 pts/0 Ss 0:01 -bash
3271 ? S 0:00 [kworker/u2:1]
3706 ? S 0:00 [kworker/u2:0]
3773 ? S 0:00 [kworker/0:2]
3904 ? S 0:00 [kworker/u2:2]
3940 ? S 0:00 [kworker/0:0]
4004 pts/0 R+ 0:00 ps axg
here is top:
35 root 10 -10 0 0 0 S 0.0 0.0 0:00.00 SMIO
36 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 deferwq
39 root 20 0 0 0 0 S 0.0 0.0 0:00.04 mmcqd/0
top - 18:59:47 up 30 min, 1 user, load average: 0.47, 0.50, 0.50
Tasks: 78 total, 1 running, 77 sleeping, 0 stopped, 0 zombie
%Cpu(s): 1.3 us, 1.3 sy, 0.0 ni, 97.4 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 445376 total, 145056 used, 300320 free, 11784 buffers
KiB Swap: 102396 total, 0 used, 102396 free, 71396 cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
4105 pi 20 0 4856 2584 2096 R 1.3 0.6 0:00.36 top
16 root 20 0 0 0 0 S 0.3 0.0 0:01.44 kworker/0:1
2803 mysql 20 0 316m 36m 9160 S 0.3 8.5 0:08.67 mysqld
3157 pi 20 0 9360 3628 3032 S 0.3 0.8 0:00.37 sshd
1 root 20 0 2164 1388 1284 S 0.0 0.3 0:01.80 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:01.41 ksoftirqd/0
5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H
7 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 khelper
8 root 20 0 0 0 0 S 0.0 0.0 0:00.01 kdevtmpfs
9 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 netns
10 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 perf
11 root 20 0 0 0 0 S 0.0 0.0 0:00.00 khungtaskd
12 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 writeback
13 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 crypto
14 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
15 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kblockd
17 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 rpciod
18 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kswapd0
19 root 20 0 0 0 0 S 0.0 0.0 0:00.00 fsnotify_mark
20 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 nfsiod
26 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kthrotld
27 root 1 -19 0 0 0 S 0.0 0.0 0:00.00 VCHIQ-0
28 root 1 -19 0 0 0 S 0.0 0.0 0:00.00 VCHIQr-0
29 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 VCHIQs-0
30 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 iscsi_eh
31 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 dwc_otg
32 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 DWC Notificatio
34 root 20 0 0 0 0 S 0.0 0.0 0:00.00 VCHIQka-0
40 root 20 0 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_0
41 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 scsi_tmf_0
42 root 20 0 0 0 0 S 0.0 0.0 0:01.02 usb-storage
43 root 20 0 0 0 0 S 0.0 0.0 0:00.06 jbd2/sda1-8
44 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 ext4-rsv-conver
159 root 20 0 2904 2216 1684 S 0.0 0.5 0:00.62 udevd
260 root 20 0 0 0 0 S 0.0 0.0 2:23.01 w1_bus_master1
301 root 20 0 2900 1960 1412 S 0.0 0.4 0:00.11 udevd
307 root 20 0 2900 1948 1412 S 0.0 0.4 0:00.00 udevd
354 root 20 0 0 0 0 S 0.0 0.0 0:00.00 spi0
389 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:1H
1601 root 20 0 1768 1168 1084 S 0.0 0.3 0:01.26 ifplugd
1608 root 20 0 1768 1196 1112 S 0.0 0.3 0:00.34 ifplugd
2033 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 cfg80211
2106 root 20 0 27992 2400 1940 S 0.0 0.5 0:00.55 rsyslogd
2182 root 20 0 2116 1368 1188 S 0.0 0.3 0:00.23 dhcpcd
2201 root 20 0 42072 15m 11m S 0.0 3.6 0:00.48 apache2
2244 root 20 0 3844 1872 1684 S 0.0 0.4 0:00.05 cron
2261 www-data 20 0 42096 6500 2372 S 0.0 1.5 0:00.00 apache2
2262 www-data 20 0 42096 6500 2372 S 0.0 1.5 0:00.00 apache2
2266 www-data 20 0 42096 6500 2372 S 0.0 1.5 0:00.00 apache2
2267 www-data 20 0 42096 6500 2372 S 0.0 1.5 0:00.00 apache2
2269 www-data 20 0 42096 6500 2372 S 0.0 1.5 0:00.00 apache2
2294 messageb 20 0 3232 1720 1488 S 0.0 0.4 0:00.01 dbus-daemon
pi@tecsud-pi ~ $
I installed on another pi and I have the problem… stuck on boot
This one i did using the android app…
Did you resize the root partition? Use the command “df -h” to check
