Wemos D1 ESP8266 based - Works with Cayenne?
Hello Guys,
The attached code works fine when using the Arduino UNO and ESP8266 board attached to it (RX to TX and TX to RX)… Now I am trying to make it work with Wemos D1 board (which doenst use the Arduino but just the ESP8266 module) but I have the following error message when trying to compile the sketch…
Arduino: 1.8.3 (Windows 7), Board: “ESPino (ESP-12 Module), 80 MHz, DIO, 115200, 4M (1M SPIFFS), ck”
Build options changed, rebuilding all
C:\Program Files (x86)\Arduino\libraries\ESP8266HardwareSerial\ESP8266.cpp:22:26: fatal error: avr/pgmspace.h: No such file or directory
#include <avr/pgmspace.h>
compilation terminated.
exit status 1
Error compiling for board ESPino (ESP-12 Module).
Code.txt (588 Bytes)
Hello, Can you try to include and recompile the code with this:
#include "CayenneDefines.h"
@cassio.lucass,
Yep. If you want to use the Wemos D1 as standalone without any other micro like a Uno, etc, then you need to run different code.
I suggest you run the supported MQTT code by going to the Dashboard and creating a new Generic ESP8266 entry, and compiling this code. I suggest you compile as a Generic ESP board also. Cayenne-MQTT-ESP/ESP8266.ino at master · myDevicesIoT/Cayenne-MQTT-ESP · GitHub
If you still want to use the Blynk Method, search Standalone ESP in the forum for the code.
ognqn.chikov Thank you, but didnt work…
@kreggly I tried both, and the Blynk Method is much easier… Thank you, it is working now.
Hi… As of now pointed at RasPi and Arduino, be that as it may within the community one part has shared a venture to form a battery fueled screen utilizing an ESP-12f and a DHT11 sensor. This screen reports its readings to the Cayenne dashboard. Just requested a few ESP-12Fs to undertake it myself. I have attempted their illustration code on a Wemos D1R2, but tragically it ceaselessly resets. (WDT). Having got the normal flicker program to run alright, I suspect I moved as well rapidly to something more complicated.
@DionGwinn Are you referring to the same development board as above?
