Hello, I am new to Pi, Arduino, and coding and am trying to get code to work in Cayenne. I have a Raspberry Pi(WiFi) and 2 Arduinos(Serial) I am trying to interface with Cayenne but every time I get the Arduino to connect it goes offline after about 10 to 15 seconds. I am pretty sure it has something to do with my code but am not sure what is wrong. I have been trying to configure existing code to work with Cayenne but haven’t succeeded yet. If anyone has any ideas on what I’m doing wrong, I would greatly appreciate any help I can get.
#include <farmBot.h>
#include <OneWire.h>
#include <EEPROM.h>
/* I2C interface requirements */
#include <Wire.h>
char username[] = "xxxxx";
char password[] = "xxxxx";
char clientID[] = "xxxxx";
/* allowcation of 1024 EEPROM */
const byte I2CID = 0;
int number = 0;
int state = 0;
double temp;
/* end I2C interface requirements */
// Pin assignment
const int ONE_WIRE_BUS = 3; // air temperature pin in
const int lightsPin = 4; // lights pin out
const int circulationFanPin = 13; // circulation fan pin out
#define VIRTUAL_CHANNEL 0
#define VIRTUAL_CHANNEL 1
#define VIRTUAL_CHANNEL 2
const int NORMAL = 1; // processing state
const int SPECIAL = 2; // processing state
const int OFF = 0; // device mode
const int ON = 1; // device mode
const int AUTO = 3; // device mode
// Setup a oneWire instance to communicate with any OneWire devices
// Pass our oneWire reference to Dallas Temperature.
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress airThermometer = { 0x28, 0x98, 0x01, 0x94, 0x97, 0x0E, 0x03, 0x40 };
//DeviceAddress outsideThermometer = { 0x28, 0x6B, 0xDF, 0xDF, 0x02, 0x00, 0x00, 0xC0 };
//DeviceAddress dogHouseThermometer = { 0x28, 0x59, 0xBE, 0xDF, 0x02, 0x00, 0x00, 0x9F };
int systemMode = NORMAL; // processing state (NORMAL, FILLTANK)
int lightsMode = AUTO; // lights mode
int lightsState = LOW; // lights current state
int lightsOnTime = 1080; // minutes that lights are ON
int lightsOffTime = 360; // minutes that lights are OFF
unsigned long lightsTimer = 0; // clock time when lights state should toggle
int circulationFanMode = AUTO; // circulation fan mode
int circulationFanState = LOW; // circulation fan current state
int circulationFanOnTime = 1; // minutes that fan is ON
int circulationFanOffTime = 2; // minutes that fan is OFF
unsigned long circulationFanTimer = 5000; // clock time when fan state should toggle
byte airTempMSB = 80; // thermometer integer full units ie. 93
byte airTempLSB = 2; // thermometer rounded to one decimal place to the right ie. .2 so together 93.2
byte airTempTarget = 82;
byte airTempDelta = 5;
int airTempSampleRate = 3; // seconds between samples
unsigned long airTempTimer = 0;
byte cmdRecieved = 0;
int cmdCnt;
int command;
pinMode(lightsPin, OUTPUT);
digitalWrite(lightsPin, lightsState); // set initial lights state
pinMode(circulationFanPin, OUTPUT);
digitalWrite(circulationFanPin, circulationFanState); // set initial fan state
i2cSetup();
oneWireSetup();
// flowSetup();
} // setup
switch (systemMode) {
case NORMAL: normalMode(); break;
case SPECIAL: specialMode(); break;
default: normalMode(); break;
} // loop
void normalMode()
if (circulationFanMode == AUTO) circulationFanControl();
if (lightsMode == AUTO) lightsControl();
} // normalMode
void circulationFanControl()
if (checkTimer(airTempTimer) == HIGH) {
getAirTemp();
airTempTimer = setSecondsTimer(airTempSampleRate); // change value to mean seconds
// Serial.print("sample temp \n");
if (airTempMSB >= airTempTarget) // turn fan on
circulationFanState = HIGH;
if (airTempMSB < airTempTarget - airTempDelta) // turn fan off
} // circulationFanControl
void lightsControl()
if (checkTimer(lightsTimer) == HIGH) {
lightsState = !lightsState;
if (lightsState == HIGH) {
lightsTimer = setMinutesTimer(lightsOnTime);
} else {
lightsTimer = setMinutesTimer(lightsOffTime);
} // end lightsControl
void specialMode()
} // specialMode
unsigned long setMinutesTimer(int waitTime)
unsigned long endTime;
endTime = millis() + (waitTime * 60000); // convert back to milliseconds from minutes
return endTime;
} // setMinutesTimer
unsigned long setSecondsTimer(int waitTime)
endTime = millis() + (waitTime * 1000); // convert back to milliseconds from seconds
return endTime;
} // setSecondsTimer
int checkTimer(unsigned long timer)
if (millis() > timer) {return HIGH;}
else {return LOW;}
} // checkTimer
void debouncePin(DEBOUNCE_DEF& target) {
long debounceDelay = 50; // the debounce time; increase if the output flickers
// read the state of the pin into a local variable:
int reading = digitalRead(target.pin);
// check to see if pin state has changed and you've waited
// long enough since the last test to ignore any noise:
if (reading != target.pinState) {
// reset the debouncing timer
target.lastDebounceTime = millis();
target.pinStable = LOW;
if (target.pinOldState == LOW) {target.pinOldState = HIGH;} else {target.pinOldState = LOW;}
if ((millis() - target.lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
target.pinStable = HIGH;
target.pinState = reading;
} // debouncePin
/* IC2 support */
void i2cSetup() {
EEPROM.write(I2CID, 0x06);
// set default i2c ID if not yet defined
// if (EEPROM.read(I2CID)==0) { EEPROM.write(I2CID, 0x4); }
// initialize i2c as slave
Wire.begin(EEPROM.read(I2CID));
// define callbacks for i2c communication
Wire.onReceive(i2cCommand);
Wire.onRequest(i2cRequest);
} // i2cSetup
void i2cCommand(int byteCount){ // callback for received data
unsigned char received;
// int cmdCnt;
// int command;
int output;
cmdCnt = Wire.available();
if (cmdCnt > 0 ) {
cmdRecieved++;
command = Wire.read(); // first byte is the command
switch (command)
case 1: // set Lights Mode (Off, On, Auto)
if (cmdCnt == 2 ) { // next byte is the mode
lightsMode = Wire.read();
switch (lightsMode) {
case ON: lightsState = HIGH; break;
case OFF: lightsState = LOW; break;
Serial.print("Lights state = ");
Serial.println(lightsState);
Serial.print("Lights Mode = ");
Serial.println(lightsMode);
break;
case 2: // set Lights auto ON time
if (cmdCnt == 3 ) { // next 2 bytes is the time
received = Wire.read();
output = (received << 8); // shift to high byte
output = output + received; // add in low byte
lightsOnTime = output; // ON time in seconds
break;
case 3: // set Lights auto OFF time
lightsOffTime = output; // OFF time in seconds
break;
case 4: // set Circulation Fan (Off, On, Auto)
circulationFanMode = Wire.read();
switch (circulationFanMode) {
case ON: circulationFanState = HIGH; break;
case OFF: circulationFanState = LOW; break;
Serial.print("Fan state = ");
Serial.println(circulationFanState);
break;
case 5: // set Circulation Fan auto ON time
circulationFanOnTime = output; // ON time in seconds
break;
case 6: // set Circulation Fan auto OFF time
circulationFanOffTime = 6001; // OFF time in seconds
// if (cmdCnt == 3 ) { // next 2 bytes is the time
// received = Wire.read();
// output = (received << 8); // shift to high byte
// output = output + received; // add in low byte
// circulationFanOffTime = 6001; // OFF time in seconds
break;
default:
Serial.print("Unhandled command # ");
Serial.print(command);
Serial.print("\n");;
break;
} // end switch
} // end if cmdCnt
} // ic2Command
void i2cRequest() { // callback for sending data
byte i2cResponse[32];
byte i2cResponseLen = 1; // response length
unsigned long currentTime = millis();
unsigned long transitionTime = 0;
byte lightsStatus = 0;
byte circulationFanStatus = 0;
String outString = "Hello";
i2cResponse[i2cResponseLen] = (byte)11; // left of decimal byte
i2cResponseLen++;
i2cResponse[i2cResponseLen] = (byte)airTempLSB; // right if decimal byte
i2cResponseLen++;
Serial.print("air temp msb = ");
Serial.println(airTempLSB);
i2cResponse[i2cResponseLen] = airTempTarget; // byte
i2cResponseLen++;
Serial.print("air temp Target = ");
Serial.println(airTempTarget);
i2cResponse[i2cResponseLen] = airTempDelta; // byte
i2cResponseLen++;
Serial.print("air temp Delta = ");
Serial.println(airTempDelta);
lightsStatus = (lightsMode << 6) | (lightsState << 5 );
circulationFanStatus = (circulationFanMode << 3) | circulationFanState << 2;
i2cResponse[i2cResponseLen] = lightsStatus | circulationFanStatus; // lights, circulation fan mode and status
i2cResponseLen++;
if (currentTime < lightsTimer) {transitionTime = lightsTimer - currentTime;} else {transitionTime = 0;}
transitionTime = transitionTime / 60000; // convert to minutes
i2cResponse[i2cResponseLen] = (byte)(transitionTime >> 8); // high byte
i2cResponseLen++;
i2cResponse[i2cResponseLen] = (byte)transitionTime; // low byte
i2cResponseLen++;
Serial.print("lights transitionTime = ");
Serial.println(transitionTime);
i2cResponse[i2cResponseLen] = (byte)(lightsOnTime >> 8); // high byte
i2cResponseLen++;
i2cResponse[i2cResponseLen] = (byte)lightsOnTime; // low byte
i2cResponseLen++;
Serial.print("lights on duration = ");
Serial.println(lightsOnTime);
i2cResponse[i2cResponseLen] = (byte)(lightsOffTime >> 8); // high byte
i2cResponseLen++;
i2cResponse[i2cResponseLen] = (byte)lightsOffTime; // low byte 17
i2cResponseLen++;
Serial.print("lights off duration = ");
Serial.println(lightsOffTime);
if (currentTime < circulationFanTimer) {transitionTime = circulationFanTimer - currentTime;} else {transitionTime = 0;}
i2cResponseLen++;
i2cResponseLen++;
Serial.print("fan transitionTime = ");
i2cResponse[i2cResponseLen] = (byte)(circulationFanOnTime >> 8); // high byte
i2cResponseLen++;
i2cResponse[i2cResponseLen] = (byte)circulationFanOnTime; // low byte
i2cResponseLen++;
Serial.print("fan on duration = ");
Serial.println(circulationFanOnTime);
i2cResponse[i2cResponseLen] = (byte)(circulationFanOffTime >> 8); // high byte
i2cResponseLen++;
i2cResponse[i2cResponseLen] = (byte)circulationFanOffTime; // low byte 22
i2cResponseLen++; // compensate for zero based array 24
Serial.print("fan off duration = ");
Serial.println(circulationFanOffTime);
Serial.print("message length = ");
Serial.println(i2cResponseLen);
Wire.write(i2cResponse, i2cResponseLen);
} // i2cRequest
double GetChipTemp(void)
{ // Get the internal temperature of the arduino
unsigned int wADC;
double t;
ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));
ADCSRA |= _BV(ADEN); // enable the ADC
delay(20); // wait for voltages to become stable.
ADCSRA |= _BV(ADSC); // Start the ADC
while (bit_is_set(ADCSRA,ADSC));
wADC = ADCW;
t = (wADC - 324.31 ) / 1.22;
return (t);
} // GetChipTemp
// end I2C support
// git clone http://github.com/jrowberg/i2cdevlib
// Reads DS18B20 "1-Wire" digital temperature sensors.
// Tutorial: http://www.hacktronics.com/Tutorials/arduino-1-wire-tutorial.html
void oneWireSetup()
// Start up the library
sensors.begin();
sensors.setResolution(airThermometer, 10); // set the resolution to 10 bit (good enough?)
// sensors.setResolution(outsideThermometer, 10);
// sensors.setResolution(dogHouseThermometer, 10);
} // oneWireSetup
float getTemperature(DeviceAddress deviceAddress)
float tempF = 70;
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00) {
// Serial.print("Error getting temperature");
} else {
tempF = DallasTemperature::toFahrenheit(tempC);
// Serial.print("C: ");
// Serial.print(tempC);
// Serial.print(" F: ");
// Serial.print(DallasTemperature::toFahrenheit(tempC));
// Serial.print("\n");;
return tempF;
void getAirTemp()
float tempF = 0;
double leftPart;
double rightPart;
double newRight;
tempF = getTemperature(airThermometer);
rightPart = modf(tempF, &leftPart);
airTempMSB = (byte)leftPart;
newRight = rightPart*10;
rightPart = modf(newRight, &leftPart);
airTempLSB = (byte)leftPart;
Serial.print("Air Temp: ");;
Serial.println(airTempMSB);
CAYENNE_OUT(V0)
//Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors.getTempCByIndex(0));
Cayenne.fahrenheitWrite(V0, sensors.getTempFByIndex(0));
CAYENNE_IN(V1)
if (getValue.asInt() == 0) {
digitalWrite(lightsPin, HIGH);
else {
digitalWrite(lightsPin, LOW);
CAYENNE_IN(V2)
digitalWrite(circulationFanPin, HIGH);
else {
digitalWrite(circulationFanPin, LOW);
// end DS18B20 support
