this feature is something we are working on right now.
Okay, thank you so much, I’m waiting.
and thank you for the attention
shramik
I altered the library CayenneArduinoMQTTClient.h
original pattern
void connect() {
CAYENNE_LOG("Connecting to %s:%d", CAYENNE_DOMAIN, CAYENNE_PORT);
int error = MQTT_FAILURE;
do {
CAYENNE_LOG("Network connect failed");
delay(1000);
else if ((error = CayenneMQTTConnect(&_mqttClient)) != MQTT_SUCCESS) {
CAYENNE_LOG("MQTT connect failed, error %d", error);
NetworkDisconnect(&_network);
delay(1000);
while (error != MQTT_SUCCESS);
Changed
void connect() {
delay(1000);
delay(1000);
Now button physique works online and offline and when cayenne connected updates status
This change may cause some bug
I ran some tests and it looks ok
Any information I appreciate
Thank you very much for your attention
shramik
I’ve run several tests and it’s working
Testes me every time
The physical button begins to appear after + - 60 seconds
When reconnecting it updates in 10 seconds
I do not see any problem in this case but I will try to reduce the time of 60 for less
know where to look in the library
the publishing time difference between two instances is set to a specific time so as to avoid hitting the rate limit and have the device disconnected. have a look at this topic Sending MQTT messages within rate limits
Thank you
My arduino is disconnecting
It is beyond the limit of messages I will correct my code
Thank you very much.
shramiksalgaonkar
Can you help me
I tried varies times but cayene still disconnects me
Can I show my code?
I’m doing something wrong, you help me.
Yes, share your code.
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN A0
#define DHTTYPE DHT11
DHT_Unified dht(DHTPIN, DHTTYPE);
#include <EEPROM.h>
#include "MQ7.h"
char username[] = "f6070370-ffbf-11e6-86d2-XXXXXXX";
char password[] = "a7b2f014cd572d647bd96f019eXXXXXXX";
char clientID[] = "dc605c00-afa4-11e8-ab9c-7XXXXXXXXXX";
unsigned long lastMillis = 0;
#define VIRTUAL_CHANNEL 1 // RELE1
#define VIRTUAL_CHANNEL 2 // RELE2
#define VIRTUAL_CHANNEL 3 // RELE3
#define VIRTUAL_CHANNEL 4 // RELE4
#define VIRTUAL_CHANNEL 5 // RELE5
#define VIRTUAL_CHANNEL 6 // RELE6
#define VIRTUAL_CHANNEL 7 // TEMPERATURA
#define VIRTUAL_CHANNEL 8 // HUMIDADE
#define VIRTUAL_CHANNEL 9 // LUX_1
#define VIRTUAL_CHANNEL 10 // LUX_2
#define VIRTUAL_CHANNEL 11 // CO2
#define RELE2_PIN 2
#define RELE3_PIN 3
#define RELE4_PIN 4
#define RELE5_PIN 5
#define RELE6_PIN 6
#define RELE7_PIN 7
#define BUTTON1_PIN 8
#define LDR A1
MQ7 mq7(A2,5.0);
dht.begin();
sensor_t sensor;
pinMode(RELE2_PIN, OUTPUT);
pinMode(RELE3_PIN, OUTPUT);
pinMode(RELE4_PIN, OUTPUT);
pinMode(RELE5_PIN, OUTPUT);
pinMode(RELE6_PIN, OUTPUT);
pinMode(RELE7_PIN, OUTPUT);
pinMode(LDR,INPUT_PULLUP);
pinMode (DHTPIN,INPUT_PULLUP);
pinMode(A2,INPUT_PULLUP);
pinMode(BUTTON1_PIN, INPUT_PULLUP);
digitalWrite(2,EEPROM.read(1));
digitalWrite(3,EEPROM.read(2));
digitalWrite(4,EEPROM.read(3));
digitalWrite(5,EEPROM.read(4));
digitalWrite(6,EEPROM.read(5));
digitalWrite(7,EEPROM.read(6));
void loop(){
if (digitalRead(BUTTON1_PIN)==LOW){
int state = digitalRead(RELE2_PIN);
digitalWrite(RELE2_PIN,!state);
lastMillis = millis();
sensors_event_t event;
dht.temperature().getEvent(&event);
Cayenne.celsiusWrite(7, event.temperature);
delay(50);
dht.humidity().getEvent(&event);
Cayenne.virtualWrite(8, event.relative_humidity, "rel_hum", "p");
delay(50);
int vout1 = analogRead(A1);
float vout = vout1/204.6;
float R = (11000-vout*2200)/vout;
//float R = pow( X, -1);
float lux = (pow( R, (1/-0.8616)))/(pow( 10, (5.118/-0.8616)));
float lux2 = 65.9 * (pow( vout1, 0.352));
Cayenne.virtualWrite(9, lux );
delay(50);
Cayenne.virtualWrite(10, lux2 );
delay(50);
Cayenne.virtualWrite(11, mq7.getPPM() );
delay(50);
Cayenne.virtualWrite(1,digitalRead(2));
delay(50);
Cayenne.virtualWrite(2, digitalRead(3));
delay(50);
Cayenne.virtualWrite(3, digitalRead(4));
delay(50);
Cayenne.virtualWrite(4,digitalRead(5));
delay(50);
Cayenne.virtualWrite(5,digitalRead(6));
delay(50);
Cayenne.virtualWrite(6,digitalRead(7));
CAYENNE_IN(1)
int value = getValue.asInt();
digitalWrite(RELE2_PIN, value);
delay(50);
EEPROM.update(1,digitalRead(2));
CAYENNE_IN(2)
digitalWrite(RELE3_PIN, value);
delay(50);
EEPROM.update(2,digitalRead(3));
CAYENNE_IN(3)
digitalWrite(RELE4_PIN, value);
delay(50);
EEPROM.update(3,digitalRead(4));
CAYENNE_IN(4)
digitalWrite(RELE5_PIN, value);
delay(50);
EEPROM.update(4,digitalRead(5));
CAYENNE_IN(5)
digitalWrite(RELE6_PIN, value);
delay(50);
EEPROM.update(5,digitalRead(6));
CAYENNE_IN(6)
digitalWrite(RELE7_PIN, value);
delay(50);
EEPROM.update(6,digitalRead(7));
Already tried if (millis() - lastMillis > 1000) 2000, 3000, 4000 and 50000
Please take a look at me.
Thank you
add this two lines and check what is causing the disconnect in your serial monitor
#define CAYENNE_DEBUG
Shramik_salgankar
I added a dimer actuator (slider) in my project, the slider works fine but the status update always returns to the value 0 I do not know what I’m doing wrong I’m going to post my code
int state;
CAYENNE_IN(13)
int state = getValue.asInt();
analogWrite(RELE7_PIN, state);
EEPROM.update(70, state);
CAYENNE_OUT(13)
Cayenne.virtualWrite(13,state);
delay(250);
Please, can you help me
appreciate
