#include <DHT.h>
#include <DHT_U.h>
#define CAYENNE_DEBUG
char username[] = "";
char password[] = "";
char clientID[] = "";
#define VIRTUAL_CHANNEL_LED2 2
#define ACTUATOR_PIN_LED2 2
#define VIRTUAL_CHANNEL_LED3 3
#define ACTUATOR_PIN_LED3 3
#define VIRTUAL_CHANNEL_FAN1 4
#define ACTUATOR_PIN_FAN1 4
#define VIRTUAL_CHANNEL_Temp 1 //is temp 36 sensor
//#define VIRTUAL_CHANNEL_DHT2 2
#define DHTPIN 8
#define DHTTYPE DHT11
#define TEMPERATURE_VIRTUAL_CHANNEL 12
#define HUMIDITY_VIRTUAL_CHANNEL 11
#define SENSOR_PIN_Motion 9
#define VIRTUAL_CHANNEL_Motion 9
#define VIRTUAL_CHANNEL_DOORLOCK 10
#define ACTUATOR_PIN_DOORLOCK 10
//Motion Sensor
int previousState = -1;
int currentState = -1;
// Analog pin the TMP36 is connected to.
const int tmpPin = 0;
const float voltage = 5.0;
TMP36 tmpSensor(tmpPin, voltage);
//DHT SENSOR
DHT dht(DHTPIN, DHTTYPE);
pinMode(SENSOR_PIN_Motion, INPUT);
pinMode(ACTUATOR_PIN_LED2, OUTPUT);
pinMode(ACTUATOR_PIN_LED3, OUTPUT);
pinMode(ACTUATOR_PIN_DOORLOCK, OUTPUT);
dht.begin();
checkSensor();
//Temp sensor
CAYENNE_OUT(VIRTUAL_CHANNEL_Temp)
Cayenne.celsiusWrite(VIRTUAL_CHANNEL_Temp, tmpSensor.getCelsius());
// To send the temperature in Fahrenheit or Kelvin use the corresponding code below.
// Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL_Temp, tmpSensor.getFahrenheit());
//Cayenne.kelvinWrite(VIRTUAL_CHANNEL_Temp, tmpSensor.getKelvin());
//motion sensor
void checkSensor()
if (currentMillis - previousMillis >= 250) {
currentState = digitalRead(SENSOR_PIN_Motion);
Cayenne.virtualWrite(VIRTUAL_CHANNEL_Motion, currentState, "digital_sensor", "d");
previousState = currentState;
//LED2
CAYENNE_IN(VIRTUAL_CHANNEL_LED2)
int value = getValue.asInt();
CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_LED2, ACTUATOR_PIN_LED2, value);
digitalWrite(ACTUATOR_PIN_LED2, value);
//LED3
CAYENNE_IN(VIRTUAL_CHANNEL_LED3)
CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_LED3, ACTUATOR_PIN_LED3, value);
digitalWrite(ACTUATOR_PIN_LED3, value);
//FAN
CAYENNE_IN(VIRTUAL_CHANNEL_FAN1)
CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_FAN1, ACTUATOR_PIN_FAN1, value);
digitalWrite(ACTUATOR_PIN_FAN1, value);
//DHT SENSOR
CAYENNE_OUT(TEMPERATURE_VIRTUAL_CHANNEL)
Cayenne.virtualWrite(TEMPERATURE_VIRTUAL_CHANNEL, dht.readTemperature(), "temp", "c");
CAYENNE_OUT(HUMIDITY_VIRTUAL_CHANNEL)
Cayenne.virtualWrite(HUMIDITY_VIRTUAL_CHANNEL, dht.readHumidity(), "rel_hum", "p");
//DOORLOCK
CAYENNE_IN(VIRTUAL_CHANNEL_DOORLOCK)
CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL_DOORLOCK, ACTUATOR_PIN_DOORLOCK, value);
digitalWrite(ACTUATOR_PIN_DOORLOCK, value);
Arduino uses digital pins 10, 11, 12, and 13 (SPI) to communicate with the W5100 on the ethernet shield. so do not use it.
Other then this, i have not found any issue in the code.
i know you are using arduino uno, but is your arduino uno capable to supply enough power to the fan? You might want to check the specs of both arduino uno pins and the fan.
if you want to check, add the #define CAYENNE_PRINT Serial back in your code and check the serial monitor if you are receiving the data from cayenne when the button is pressed.
