I’m new to cayenne and am struggling a lot to connect my devices.
My setup is as follows.
Arduino UNO
ESP-01s
Logic level converter
The issue I’m having is 2 parts.
The cayenne library is no longer available in library manager only cayenneMQTT is available.
When I select uno from my devices setup it goes to step 2 which says the following.
connect WiFi or ethernet shield
download Arduino IDE
install cayenne library (not available as mentioned above!)
select tools>board your board and com port.
I followed these steps and the browser won’t allow me to click next and the videos don’t seem to be for the current version of cayenne my devices website as it looks completely different.
As a workaround, can you use the cayenne android app to add a new device and email the MQTT credentials. Once you run the code, you shall be able to use the cayenne web dashboard.
