Sorry, there is no other way. Though there is a workaround, you can use one device to collect sensor and another device to send data. Use any communication protocol to transmit data between the two devices.
So I coud connect the sensor to a UNO and transmit everything to MEGA whish connects to Cayenne?
Any examples available?
there is no example available, you got to do it on your own.
I guess the best would be serial to serial communication, correct?
hii shramik !! i’ am facing the same thing here … everything was working fine and i don’ t know why i lost the connection to the internet (even on all pc ) and when i tryed to start again with the esp8266 i have the same error code
[986864] Disconnected
[986864] Connecting to mqtt.mydevices.com:1883
[1017089] MQTT connect failed, error -1
[1048288] MQTT connect failed, error -1
[1079486] MQTT connect failed, error -1
[1110702] MQTT connect failed, error -1
can’t login again tryed many times …i don’t thing it’s the provider …i use mqtt since 1 month as least …any help would be nice
can you try connecting to mydevices using telnet telnet mqtt.mydevices.com 1883
i don’t know where to add this part in my code (( telnet mqtt.mydevices.com 1883 ))???
here’s how it strat
#include <Adafruit_Sensor.h>
//#define CAYENNE_DEBUG
#define DATA_CHANNEL 0 //Virtual channel for publishing sensor data.
#define TRIGGER_CHANNEL 1 //Virtual channel for publishing the trigger value.
#define THRESHOLD 200 //Threshold for the trigger.
bool sendBelowThreshold = true; //Set to true if the trigger should happen when the data value is below the threshold,
//false if it should happen when the data value is above or equal to the threshold.
bool crossedThreshold = false;
char ssid = “";
char wifiPassword[] = "********”;
char username = “***************************";
char password[] = "";
char clientID[] = "”;
ok thank you shramik i will try this !!! thanks for your time again
