New user to Cayenne. Have followed all directions for installing a new device but when I run it the widget that’s supposed to pop up on the dashboard does not appear. I’m using a generic ESP8266 device with one of the example sketches from the CayenneMQTT library (version 1.3.0 installed). I have all my credentials entered in the sketch. I get a “connected” message from my serial monitor so I know I’m online with the Cayenne platform. I’m expecting a data value on channel 0 to appear but nothing happens. Any suggestions?
Can you share the code you are using. Add #define CAYENNE_DEBUG in your code and check the serial monitor to see the data published. Once connected and data is published you will see green temporary widgets on the cayenne dashboard. Click on the + on the top right corner of each widget to make them permanent.
Here is the sketch (from the Cayenne library):
char ssid = “xxxxxxx”;
char wifiPassword = “xxxxxxxx”;
char username = “xxxxxxx”;
char password = “xxxxxxx”;
char clientID = “xxxxxxx”;
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
And here is a sample serial monitor readout:
12:32:47.977 → [4553] Connected to WiFi
12:32:48.012 → [4554] IP: 192.168.1.77
12:32:48.012 → [4554] Connecting to mqtt.mydevices.com:1883
12:32:48.320 → [4911] Connected
12:32:48.388 → [4962] Publish: topic 4, channel 65534, value Arduino, subkey , key
12:32:48.458 → [4964] Publish: topic 6, channel 65534, value Xtensa32, subkey , key
12:32:48.526 → [4977] Publish: topic 7, channel 65534, value 80000000, subkey , key
12:32:48.595 → [5051] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
12:32:48.663 → [5122] Publish: topic 8, channel 65534, value ESP8266, subkey , key
12:32:50.595 → [7201] Publish: topic 1, channel 0, value 7200, subkey , key
12:32:59.632 → [16228] Connection ok
12:33:05.646 → [22246] Publish: topic 1, channel 0, value 22246, subkey , key
Still no green widgets appear in my dashboard…
can you private message me your email_id.
Probably having the same problem with an other setup: Arduino MKR 1400 GSM
Thanks in advance
