#include <CayenneLPP.h>
#include <DHTesp.h>
//#include <Adafruit_GPS.h>
#include <HardwareSerial.h>
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <Wire.h>
#include <math.h>
#include "SSD1306.h"
// LoRaWAN NwkSKey, network session key
static const PROGMEM u1_t NWKSKEY[16] = { 0x7a, 0x6b, 0x75, 0x7a, 0x09, 0x03, 0x0d, 0xb4, 0x2a, 0x20, 0x3a, 0xa5, 0x60, 0xff, 0x13,0x2c };
// LoRaWAN AppSKey, application session key
static const u1_t PROGMEM APPSKEY[16] = { 0x53, 0x40, 0xca, 0xf4, 0xbe, 0x26, 0x7b, 0x3c, 0xdd, 0x9a, 0x1c, 0xd4, 0x8f, 0x70, 0x05,0x57 };
// LoRaWAN end-device address (DevAddr)
static const u4_t DEVADDR = { 0x2601306c };
// These callbacks are only used in over-the-air activation, so they are
// left empty here (we cannot leave them out completely unless
// DISABLE_JOIN is set in config.h, otherwise the linker will complain).
void os_getArtEui (u1_t* buf) { }
void os_getDevEui (u1_t* buf) { }
void os_getDevKey (u1_t* buf) { }
static osjob_t sendjob;
// Schedule data trasmission in every this many seconds (might become longer due to duty
// cycle limitations).
// we set 10 seconds interval
const unsigned TX_INTERVAL = 60; // Fair Use policy of TTN requires update interval of at least several min. We set update interval here of 1 min for testing
// Pin mapping according to Cytron LoRa Shield RFM
const lmic_pinmap lmic_pins = {
.nss = 18,
.rxtx = LMIC_UNUSED_PIN,
.rst = 14,
.dio = {26, 33, 32},
/** Pin number for DHT11 data pin */
int dhtPin_1 = 25 ;
int dhtPin_2 = 15 ;
int dhtPin_3 = 17 ;
// Adafruit GPS
//#define SERIAL1_RXPIN 12
//#define SERIAL1_TXPIN 13
//HardwareSerial gpsSerial(2); // use ESP32's 2nd serial port (default serial 1 is for debug)
//Adafruit_GPS GPS(&gpsSerial);
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences
//#define GPSECHO true
CayenneLPP lpp(15);
DHTesp dht1;
DHTesp dht2;
DHTesp dht3;
SSD1306 display(0x3c, 4, 34);
void onEvent (ev_t ev)
Serial.print(os_getTime());
Serial.print(": ");
switch(ev)
case EV_TXCOMPLETE:
Serial.printf("EV_TXCOMPLETE (includes waiting for RX windows)\r\n");
// Schedule next transmission
os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
break;
case EV_RXCOMPLETE:
if (LMIC.dataLen)
Serial.printf("Received %d bytes\n", LMIC.dataLen);
break;
default:
Serial.printf("Unknown event\r\n");
break;
void do_send(osjob_t* j)
// Check if there is not a current TX/RX job running
if (LMIC.opmode & OP_TXRXPEND)
Serial.printf("OP_TXRXPEND, not sending\r\n");
else
if (!(LMIC.opmode & OP_TXRXPEND))
TempAndHumidity newValues1 = dht1.getTempAndHumidity();
TempAndHumidity newValues2 = dht2.getTempAndHumidity();
TempAndHumidity newValues3 = dht3.getTempAndHumidity();
String temp_data= String(String(newValues1.temperature) + ' ' + String(newValues2.temperature) + ' ' +String(newValues3.temperature));
String hum_data= String(String(newValues1.humidity)+' ' + String(newValues2.humidity)+' ' +String(newValues3.humidity));
lpp.reset();
// delay(800);
lpp.addTemperature(1,newValues1.temperature);
lpp.addRelativeHumidity(2,newValues1.humidity);
// delay(1200);
lpp.addTemperature(3,newValues2.temperature);
lpp.addRelativeHumidity(4,newValues2.humidity);
delay(200);
//newValues3.temperature=50;
//newValues3.humidity=100;
lpp.addTemperature(5,newValues3.temperature);
lpp.addRelativeHumidity(6,newValues3.humidity);
// delay(2500);
// Serial.print(temp_data);
// Serial.print(hum_data);
// delay(1000);
Serial.printf("Temperature : %.2f, Humidity : %.2f\r\n", newValues1.temperature, newValues1.humidity);
// delay(1600);
Serial.printf("Temperature : %.2f, Humidity : %.2f\r\n", newValues2.temperature, newValues2.humidity);
// delay(2000);
Serial.printf("Temperature : %.2f, Humidity : %.2f\r\n", newValues3.temperature, newValues3.humidity);
// delay(2500);
display.drawString(0, 0, "Temperature: ");
display.drawString(90, 0, String(newValues1.temperature));
display.drawString(0, 20, "Humidity : ");
display.drawString(90,20, String(newValues1.humidity));
display.display();
#if 0
// Now for GPS
// if (GPS.fix)
// float lat = GPS.latitudeDegrees;
// float lon = GPS.longitudeDegrees;
// float alt = GPS.geoidheight;
// Serial.printf("GPS lat = %.2f, lon = %.2f, alt = %.2f\n", lat, lon, alt);
// lpp.addGPS(7, lat, lon, alt);
#endif
// Prepare upstream data transmission at the next possible time.
LMIC_setTxData2(1, lpp.getBuffer(), lpp.getSize(), 0);
Serial.printf("Packet queued\r\n");
// Next TX is scheduled after TX_COMPLETE event.
Serial.begin(115200);
// gpsSerial.begin(115200, SERIAL_8N1, SERIAL1_RXPIN, SERIAL1_TXPIN);
Serial.printf("Starting...\r\n");
pinMode(16,OUTPUT);
digitalWrite(16, LOW); // set GPIO16 low to reset OLED
delay(50);
digitalWrite(16, HIGH);
display.init();
display.setFont(ArialMT_Plain_10);
dht1.setup(dhtPin_1, DHTesp::DHT11);
dht2.setup(dhtPin_2, DHTesp::DHT11);
dht3.setup(dhtPin_3, DHTesp::DHT11);
#if 0
// 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
// GPS.begin(9600);
// uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
// GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
// uncomment this line to turn on only the "minimum recommended" data
//GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
// For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
// the parser doesn't care about other sentences at this time
// Set the update rate
// GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
// For the parsing code to work nicely and have time to sort thru the data, and
// print it out we don't suggest using anything higher than 1 Hz
// Request updates on antenna status, comment out to keep quiet
GPS.sendCommand(PGCMD_ANTENNA);
#endif
// LMIC init
os_init();
// Reset the MAC state. Session and pending data transfers will be discarded.
LMIC_reset();
// Set static session parameters. Instead of dynamically establishing a session
// by joining the network, precomputed session parameters are be provided.
uint8_t appskey[sizeof(APPSKEY)];
uint8_t nwkskey[sizeof(NWKSKEY)];
memcpy_P(appskey, APPSKEY, sizeof(APPSKEY));
memcpy_P(nwkskey, NWKSKEY, sizeof(NWKSKEY));
LMIC_setSession (0x1, DEVADDR, nwkskey, appskey);
// Select frequencies range
// LMIC_selectSubBand(0);
// Disable link check validation
LMIC_setLinkCheckMode(0);
// TTN uses SF9 for its RX2 window.
LMIC.dn2Dr = DR_SF9;
// Set data rate and transmit power for uplink (note: txpow seems to be ignored by the library)
LMIC_setDrTxpow(DR_SF7,14);
Serial.printf("LMIC setup done!\r\n");
// Start job
do_send(&sendjob);
do_send(&sendjob);
delay(5000);
#if 0
char c = GPS.read();
// if you want to debug, this is a good time to do it!
//if ((c) && (GPSECHO))
// Serial.write(c);
// if a sentence is received, we can check the checksum, parse it...
// if (GPS.newNMEAreceived())
// a tricky thing here is if we print the NMEA sentence, or data
// we end up not listening and catching other sentences!
// so be very wary if using OUTPUT_ALLDATA and trytng to print out data
//Serial.println(GPS.lastNMEA()); // this also sets the newNMEAreceived() flag to false
// if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
// ; //return; // we can fail to parse a sentence in which case we should just wait for another
#endif
// Make sure LMIC is ran too
os_runloop_once();
thank you for sharing the code. what issue are you facing? can you provide more info.
Hello! Shramik,
I can get data for 4 details of the sensor due to channel available and I want to connect three DHT11 Sensor so I can get 6 values (Temperature and Humidity).
Could you please help me with this so I can send multiple data on Cayenne.
not sure I follow what you are mentioning.
