Digital Output Raspberry Python
This is my code :
import cayenne.client #Cayenne MQTT Client from gpiozero import LED
led=LED(17) #Declaring button pin 17
#Cayenne authentication info. This should be obtained from the Cayenne Dashboard.
MQTT_USERNAME = “8a58db60-”
MQTT_PASSWORD = “8aaf623135c1f2e6fe6de2d3b1a88”
MQTT_CLIENT_ID = “d5bfb780-ca3-552aaa” # The callback for when a message is received from Cayenne.
def on_message(message):
if message.channel==1: #Dashboard Led widget channel. They must be same.
if message.value==“1”: #If led command “1”, turn led on(message.value must be string)
led.on()
elif message.value==“0”: #If led command “0”, turn led off(message.value must be string)
led.off()
client.on_message = on_message #When message recieved from Cayenne run on_message function
while True:
client.loop()
root@osmc:/home/osmc# sudo python guzik.py
File “guzik.py”, line 2, in
NameError: name ‘LED’ is not defined
Where is problem thx
first try this RPi.GPIO basics 5 – Setting up and using outputs with RPi.GPIO – RasPi.TV and get the output without the cayenne code.
LED just about to switch off
LED just about to switch on
:slight_smile:
now looking at the LED code, add there the lines which are used to turn ON and OFF in the cayenne code when you receive data from the button:
    if (message.channel == 4) and (message.value == "1"):
        #code to turn ON the led
MQTT_USERNAME = “”
MQTT_PASSWORD = “”
MQTT_CLIENT_ID = “”
if (message.channel == 1) and (message.value == “1”):
print(“guzik on”)
elif (message.value==“0”):
print(“guzik off”)
while True:
client.loop()
File “guzik.py”, line 9
print(“guzik on”)
IndentationError: expected an indented block
you need to have indented space left in python or you will get error. Have a look at this Have a look at this 4. Structuring with Indentation | Python Tutorial | python-course.eu
