Hi, I wanted to ask if it is possible to connect a gateway from Dragino LG01-N using MQTT similar to ThingSpeak. Where I don’t like 15 seconds of delay between dates. I entered the password, name and ID. But I don’t know what to set up for Channel Management. I will be happy for advice.
You need to connect the gateway to a Network Server and then use cayenne integration in the NS application to forward data from the node to the gateway to cayenne.
Okay, so cayenne doesn’t work independently with MQTT as well as ThingSpeak?
