Hello everyone I am trying to connect in cayenne the following:
- arduino uno
- wifi w5100 module
- BMP180 Temperature
By following all instructions I have to copy the following code:
Cayenne BMP180 Example
This sketch shows how to send BMP180 Sensor data to the Cayenne Dashboard.
Steps:
1. Install the Adafruit Unified Sensor library (https://github.com/adafruit/Adafruit_Sensor) from the Arduino Library Manager.
2. Install the Adafruit BMP085 Unified library (https://github.com/adafruit/Adafruit_BMP085_Unified) from the Arduino Library Manager.
3. Attach a BMP180 to your Arduino.
Schematic:
BMP180 Arduino
[VDD] --- [3V3]
[GND] --- [GND]
[SDA] --- [Analog Pin 4] (The SDA may be different on some devices, e.g. for Arduino Mega the SDA pin is Digital Pin 20)
[SCL] --- [Analog Pin 5] (The SCL may be different on some devices, e.g. for Arduino Mega the SCL pin is Digital Pin 21)
4. Set the TEMPERATURE_VIRTUAL_CHANNEL value below to a free virtual channel (or the temperature channel of the BMP180 Sensor widget you have added) in the Dashboard.
5. Set the BAROMETER_VIRTUAL_CHANNEL value below to a free virtual channel (or the pressure channel of the BMP180 Sensor widget you have added) in the Dashboard.
6. Set the Cayenne authentication info to match the authentication info from the Dashboard.
7. Compile and upload this sketch.
8. Once the Arduino connects to the Dashboard it should automatically create temporary display widgets (or update the BMP180 Sensor widgets you have added) with data.
To make a temporary widget permanent click the plus sign on the widget.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h>
char username[] = "64**********************65";
char password[] = "783******************************";
char clientID[] = "68***********************************
#define TEMPERATURE_VIRTUAL_CHANNEL 2
#define BAROMETER_VIRTUAL_CHANNEL 2
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10180);
bool bmpSensorDetected = true;
if (!bmp.begin())
CAYENNE_LOG("No BMP sensor detected");
bmpSensorDetected = false;
// This function is called at intervals to send temperature sensor data to Cayenne.
CAYENNE_OUT(TEMPERATURE_VIRTUAL_CHANNEL)
if (bmpSensorDetected)
float temperature;
bmp.getTemperature(&temperature);
// Send the value to Cayenne in Celsius.
Cayenne.celsiusWrite(TEMPERATURE_VIRTUAL_CHANNEL, temperature);
else
// This function is called at intervals to send barometer sensor data to Cayenne.
CAYENNE_OUT(BAROMETER_VIRTUAL_CHANNEL)
// Send the command to get data.
sensors_event_t event;
bmp.getEvent(&event);
if (event.pressure)
// Send the value to Cayenne in hectopascals.
Cayenne.hectoPascalWrite(BAROMETER_VIRTUAL_CHANNEL, event.pressure);
else
While I try to verify I get the following error:
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
D:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Arduino\hardware -hardware C:\Users\AppData\Local\Arduino15\packages -tools D:\Arduino\tools-builder -tools D:\Arduino\hardware\tools\avr -tools C:\Users\AppData\Local\Arduino15\packages -built-in-libraries D:\Arduino\libraries -libraries C:\Users...Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10819 -build-path C:\Users\AppData\Local\Temp\arduino_build_100427 -warnings=none -build-cache C:\Users\AppData\Local\Temp\arduino_cache_990862 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=D:\Arduino\hardware\tools\avr -verbose C:\Users...Documents\Arduino\sketch_may29a\sketch_may29a.ino
D:\Arduino\arduino-builder -compile -logger=machine -hardware D:\Arduino\hardware -hardware C:\Users\AppData\Local\Arduino15\packages -tools D:\Arduino\tools-builder -tools D:\Arduino\hardware\tools\avr -tools C:\Users\AppData\Local\Arduino15\packages -built-in-libraries D:\Arduino\libraries -libraries C:\Users...Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10819 -build-path C:\Users\AppData\Local\Temp\arduino_build_100427 -warnings=none -build-cache C:\Users\AppData\Local\Temp\arduino_cache_990862 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=D:\Arduino\hardware\tools\avr -verbose C:\Users...Documents\Arduino\sketch_may29a\sketch_may29a.ino
Using board 'uno' from platform in folder: D:\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: D:\Arduino\hardware\arduino\avr
Detecting libraries used...
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\...\\AppData\\Local\\Temp\\arduino_build_100427\\sketch\\sketch_may29a.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\...\\AppData\\Local\\Temp\\arduino_build_100427\\sketch\\sketch_may29a.ino.cpp" -o nul
Alternatives for Adafruit_Sensor.h: [Adafruit_Unified_Sensor-1.1.5@1.1.5]
ResolveLibrary(Adafruit_Sensor.h)
-> candidates: [Adafruit_Unified_Sensor-1.1.5@1.1.5]
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "C:\\Users\\...\\AppData\\Local\\Temp\\arduino_build_100427\\sketch\\sketch_may29a.ino.cpp" -o nul
Alternatives for Adafruit_BMP085_U.h: [Adafruit_BMP085_Unified-1.1.1@1.1.1]
ResolveLibrary(Adafruit_BMP085_U.h)
-> candidates: [Adafruit_BMP085_Unified-1.1.1@1.1.1]
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "C:\\Users\\...\\AppData\\Local\\Temp\\arduino_build_100427\\sketch\\sketch_may29a.ino.cpp" -o nul
Alternatives for CayenneMQTTEthernet.h: [CayenneMQTT@1.2.0]
ResolveLibrary(CayenneMQTTEthernet.h)
-> candidates: [CayenneMQTT@1.2.0]
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "C:\\Users\\...\\AppData\\Local\\Temp\\arduino_build_100427\\sketch\\sketch_may29a.ino.cpp" -o nul
Alternatives for Ethernet.h: [Ethernet@2.0.0]
ResolveLibrary(Ethernet.h)
-> candidates: [Ethernet@2.0.0]
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\AppData\\Local\\Temp\\arduino_build_100427\\sketch\\sketch_may29a.ino.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "D:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\Wire.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "D:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\utility\\twi.c" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5\\Adafruit_Sensor.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1\\Adafruit_BMP085_U.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src\\CayenneHandlers.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src\\CayenneMQTTClient\\CayenneMQTTClient.c" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src\\CayenneMQTTClient\\MQTTClient.c" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src\\CayenneUtils\\CayenneDataArray.c" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src\\CayenneUtils\\CayenneUtils.c" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src\\MQTTCommon\\MQTTConnectClient.c" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src\\MQTTCommon\\MQTTDeserializePublish.c" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src\\MQTTCommon\\MQTTPacket.c" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src\\MQTTCommon\\MQTTSerializePublish.c" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src\\MQTTCommon\\MQTTSubscribeClient.c" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src\\MQTTCommon\\MQTTUnsubscribeClient.c" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src\\Platform\\Arduino\\MQTTArduino.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "D:\\Arduino\\libraries\\Ethernet\\src\\Dhcp.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "D:\\Arduino\\libraries\\Ethernet\\src\\Dhcp.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "D:\\Arduino\\libraries\\Ethernet\\src\\Dns.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "D:\\Arduino\\libraries\\Ethernet\\src\\Ethernet.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "D:\\Arduino\\libraries\\Ethernet\\src\\EthernetClient.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "D:\\Arduino\\libraries\\Ethernet\\src\\EthernetServer.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "D:\\Arduino\\libraries\\Ethernet\\src\\EthernetUdp.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "D:\\Arduino\\libraries\\Ethernet\\src\\socket.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "D:\\Arduino\\libraries\\Ethernet\\src\\utility\\w5100.cpp" -o nul
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "D:\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src\\SPI.cpp" -o nul
Generating function prototypes...
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\...\\AppData\\Local\\Temp\\arduino_build_100427\\sketch\\sketch_may29a.ino.cpp" -o "C:\\Users\\...\\AppData\\Local\\Temp\\arduino_build_100427\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"D:\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\...\\AppData\\Local\\Temp\\arduino_build_100427\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"D:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-ID:\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_Unified_Sensor-1.1.5" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_BMP085_Unified-1.1.1" "-IC:\\Users\\...\\OneDrive\\Documenti\\Arduino\\libraries\\CayenneMQTT\\src" "-ID:\\Arduino\\libraries\\Ethernet\\src" "-ID:\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\...\\AppData\\Local\\Temp\\arduino_build_100427\\sketch\\sketch_may29a.ino.cpp" -o "C:\\Users\\...\\AppData\\Local\\Temp\\arduino_build_100427\\sketch\\sketch_may29a.ino.cpp.o"
In file included from C:\Users...Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoDefines.h:128:0,
from C:\Users...Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:21,
from C:\Users...Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTEthernetClient.h:21,
from C:\Users...Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTEthernet.h:25,
from C:\Users...Documents\Arduino\sketch_may29a\sketch_may29a.ino:30:
C:\Users...Documents\Arduino\sketch_may29a\sketch_may29a.ino: In function 'void OutputHandler2(Request&)':
C:\Users...Documents\Arduino\libraries\CayenneMQTT\src/CayenneHandlers.h:69:37: error: redefinition of 'void OutputHandler2(Request&)'
#define CAYENNE_OUT_2(channel) void OutputHandler ## channel (Request& request)
C:\Users...Documents\Arduino\libraries\CayenneMQTT\src/CayenneHandlers.h:71:30: note: in expansion of macro 'CAYENNE_OUT_2'
#define CAYENNE_OUT(channel) CAYENNE_OUT_2(channel)
C:\Users...Documents\Arduino\sketch_may29a\sketch_may29a.ino:76:1: note: in expansion of macro 'CAYENNE_OUT'
C:\Users...Documents\Arduino\libraries\CayenneMQTT\src/CayenneHandlers.h:69:37: note: 'void OutputHandler2(Request&)' previously defined here
C:\Users...Documents\Arduino\sketch_may29a\sketch_may29a.ino:60:1: note: in expansion of macro 'CAYENNE_OUT'
Using library Wire at version 1.0 in folder: D:\Arduino\hardware\arduino\avr\libraries\Wire
Using library Adafruit_Unified_Sensor-1.1.5 at version 1.1.5 in folder: C:\Users...Documents\Arduino\libraries\Adafruit_Unified_Sensor-1.1.5
Using library Adafruit_BMP085_Unified-1.1.1 at version 1.1.1 in folder: C:\Users...Documents\Arduino\libraries\Adafruit_BMP085_Unified-1.1.1
Using library CayenneMQTT at version 1.2.0 in folder: C:\Users...Documents\Arduino\libraries\CayenneMQTT
Using library Ethernet at version 2.0.0 in folder: D:\Arduino\libraries\Ethernet
Using library SPI at version 1.0 in folder: D:\Arduino\hardware\arduino\avr\libraries\SPI
exit status 1
Error compiling for board Arduino Uno.
