Dear All,
I am trying to connect an ESP32 board to Cayene throuhy CAYENNE_OUT function using wifi as the connection below (code below).
I constant get the “‘Cayenne’ was not declared in this scope” message and I am using a TTGO LoRa ESP32 board set as ESP32 dev board in the boards manager.
I have noticed that by trying different board types as well as Cayene MQTT libraries, I get different error messages that mainly point to WiFi library problems.
Has anyone come across the same issues?
Thank you
#include <LoRa.lyh>
//#include "SSD1306.h"
#include <Arduino.h>
//#include <CayenneArduinoDefines.h>
//#include <CayenneMQTTWiFi.h>
//#include <CayenneMQTTESP32.h>
#include <SPI.h>
//#include <WiFi.h>
//Libraries for OLED Display
#include <Wire.h>
#include <Adafruit_GFX.h>
//#include <Adafruit_SSD1306.h>
#define CAYENNE_DEBUG
#define VIRTUAL_CHANNEL 5
char ssid[] = "";
char wifiPassword[]="s";
char username[] = "";
char mqtt_password[] = "";
char clientID[] = "";
//SSD1306  display(0x3c, 4, 15);
//OLED pins to ESP32 GPIOs via this connection:
//OLED_SDA -- GPIO4
//OLED_SCL -- GPIO15
//OLED_RST -- GPIO16
// WIFI_LoRa_32 ports
// GPIO5  -- SX1278's SCK
// GPIO19 -- SX1278's MISO
// GPIO27 -- SX1278's MOSI
// GPIO18 -- SX1278's CS
// GPIO14 -- SX1278's RESET
// GPIO26 -- SX1278's IRQ(Interrupt Request)
#define SS      18
#define RST     14
#define DI0     26
#define BAND    868E6
//float data;
String data = "";
int rssi = LoRa.packetRssi();
#define BUTTON_PIN_BITMASK 0x200000000 // 2^33 in hex
RTC_DATA_ATTR int bootCount = 0;
Method to print the reason by which ESP32
has been awaken from sleep
void print_wakeup_reason(){
  esp_sleep_wakeup_cause_t wakeup_reason;
  wakeup_reason = esp_sleep_get_wakeup_cause();
  switch(wakeup_reason)
    case ESP_SLEEP_WAKEUP_EXT0 : Serial.println("Wakeup caused by external signal using RTC_IO"); break;
    case ESP_SLEEP_WAKEUP_EXT1 : Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
    case ESP_SLEEP_WAKEUP_TIMER : Serial.println("Wakeup caused by timer"); break;
    case ESP_SLEEP_WAKEUP_TOUCHPAD : Serial.println("Wakeup caused by touchpad"); break;
    case ESP_SLEEP_WAKEUP_ULP : Serial.println("Wakeup caused by ULP program"); break;
    default : Serial.printf("Wakeup was not caused by deep sleep: %d\n",wakeup_reason); break;
  Cayenne.begin(username, mqtt_password, clientID, ssid, wifiPassword);
  pinMode(16,OUTPUT);
  digitalWrite(16, LOW);    // set GPIO16 low to reset OLED
  delay(50);
  digitalWrite(16, HIGH);
//  display.init();
//  display.flipScreenVertically();
//  display.setFont(ArialMT_Plain_10);
//  display.setTextAlignment(TEXT_ALIGN_LEFT);
  Serial.begin(115200);
  while (!Serial); //if just the the basic function, must connect to a computer
  delay(1000);
  Serial.println("LoRa Receiver");
//  display.drawString(5,5,"LoRa Receiver");
//  display.display();
//  SPI.begin(5,19,27,18);
  LoRa.setPins(SS,RST,DI0);
  if (!LoRa.begin(BAND)) {
   // display.drawString(5,25,"Starting LoRa failed!");
    while (1);
  Serial.println("LoRa Initial OK!");
//  display.drawString(5,25,"LoRa Initializing OK!");
delay(1000); //Take some time to open up the Serial Monitor
  //Increment boot number and print it every reboot
  ++bootCount;
  Serial.println("Boot number: " + String(bootCount));
  //Print the wakeup reason for ESP32
  print_wakeup_reason();
  esp_sleep_enable_ext0_wakeup(GPIO_NUM_33,1); //1 = High, 0 = Low
  //Go to sleep now
  //Serial.println("Going to sleep now");
  //delay(1000);
  //esp_deep_sleep_start();
  //Serial.println("This will never be printed");
//  Cayenne.loop();
  // try to parse packet
  int packetSize = LoRa.parsePacket();
  String data = "";
  if (packetSize) {
    // received a packets
    Serial.println("Received packet. ");
    //display.clear();
    //display.setFont(ArialMT_Plain_16);
    //display.drawString(20, 5, "Received packet value:  ");
    Serial.println("Received packet value:  ");
    // read packet
    while (LoRa.available()) {
      data = LoRa.readString();
      //String data = String(LoRa.read());
      //Serial.print((char)LoRa.read());
     Serial.println(data);
    //Serial.print("kitsos");
  //  display.drawString(20,22, data);
    // print RSSI of packet
    Serial.print(" with RSSI ");
       Serial.println(LoRa.packetRssi());
        //display.drawString(20, 45, "RSSI:  ");
               String rssi = String(LoRa.packetRssi());
        //display.drawString(70, 45, String (LoRa.packetRssi());
               //display.drawString(70, 45, String(rssi));
    //display.display();
 //Go to sleep now
  delay(1000);
// This function is called at intervals to send data to Cayenne.
CAYENNE_OUT(VIRTUAL_CHANNEL)
  //CAYENNE_LOG("Send data for Virtual Channel %d", VIRTUAL_CHANNEL);
  // This command writes the device's uptime in seconds to the Virtual Channel.
 //Cayenne.virtualWrite(VIRTUAL_CHANNEL, data);
