ESP8266 Nodemcu Slider Coding Issue
Hello all!
I am very new to Cayenne and Arduino coding as a whole and I am currently facing an issue working the slider widget on Cayenne with the ESP8266 Nodemcu 0.9. The issue is that when I move my slider, the values aren’t updating in the code. Beyond this issue, I am have troubles seeing my sensor, HX711, data on the dashboard. Any help is MUCH appreciated as soon as possible. This is for a project due ASAP. Please refer to the code below. Thank you Cayenne Community!
//#define CAYENNE_DEBUG
//#include <CayenneMQTTClient.h>
#include <HX711.h>
#define Buzzerout D2 //D2
#define DOUT D4 //D4
#define CLK D5 //D5
#define LEDout D6 //D6
char ssid = “SSID”;
char wifiPassword = “PASSWORD”;
char username = “USER NAME”;
char password = “PASSWORD”;
char clientID = “CLIENTID”;
Network network;
CayenneMQTTClient mqttClient;
#define VIRTUAL_CHANNEL 3
#define VIRTUAL_CHANNEL2 4
#define VIRTUAL_CHANNEL3 0
HX711 scale;
float calibration_factor=5220;
float units;
float ounces;
float percent_load = .10;
float person_weight = 170;
float weightmath;
float notifmethod=1;
unsigned long lastMillis = 0;
// SETUP //
scale.begin(DOUT, CLK);
pinMode(Buzzerout, OUTPUT);
digitalWrite(Buzzerout, HIGH);
scale.set_scale(5220.f);
scale.tare();
// LOOP //
weightmath=(percent_load * person_weight);
units=(scale.get_units(10), 1);
if (units < 0){
units= 0.00;
// Insert an if statement here which select this notification method
if (units > weightmath){
digitalWrite(Buzzerout, LOW);
delay(500);
} Serial.println(weightmath);
Serial.println(percent_load);
Serial.println(person_weight);
CAYENNE_OUT_DEFAULT()
Cayenne.virtualWrite(0, weightmath);
CayenneMQTTPublishDataFloat(&mqttClient, NULL, DATA_TOPIC, 0, “VALUE”, “ANALOG”, weightmath);
//Cayenne.virtualWrite(3, units);
//Cayenne.virtualWrite(4, percent);
CAYENNE_IN_DEFAULT()
CAYENNE_IN(VIRTUAL_CHANNEL){
int PersWght = getValue.asInt();
person_weight = (PersWght);
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL, person_weight);
analogWrite(DOUT, person_weight);
CAYENNE_IN(VIRTUAL_CHANNEL2){
int PersPcnt = getValue.asInt();
percent_load = (PersPcnt);
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL2, percent_load);
analogWrite(DOUT, percent_load);
Before trying the cayenne code, can you try the HX711 code alone to see if you are getting data from the sensor.
why are you using this line?
