This is a project for a small temperature, humidity, and batter voltage monitor so I can track what the weather is doing outside using the Wemos D1 Mini Pro. It uses the esp8266 library to sleep for 10 min (just changed to 20 min) and then wake, take readings, transmit to cayenne, and then sleep again. I use the EEPROM to store the sleep value (if it sleeps or not) and it reads it when the chip resets. The thing about the ESP8266 in this instance is that rather than just waking up, it triggers a reset so thats why I had to use the EEPROM to store the value. It uses the SHT3x temp/hum sensor which is I2C. I also used a D1 Mini shield to do a voltage divider so I can monitor the battery voltage and a Charger Shield to charge the battery. To get the chip out of a sleep loop, one either has to wait till it comes online briefly and unselect the sleep button or you can put a jumper GRD → D7 to disable the sleep cycle. You also need a jumper from D0 (GPIO16 aka wake pin) —> RST to enable the chip to wake itself up. I also thought the ESP8266 only read between 0-1v on the analog pin but I tested it and it definitely reads all the way to 3.3v on this chip anyway. Weird
// #define CAYENNE_DEBUG Serial
// #define CAYENNE_PRINT Serial
#include <Wire.h>
#include <ESP8266WiFi.h>
#include <EEPROM.h>
RF_MODE(RF_NO_CAL) // tells the ESP to just turn on radio, no calibration which extra takes power
char ssid[] = "IoT";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
#define Address 0x45 // wire address for the SHT3x
#define eepromAddress 0 // where sleep cycle status is stored
#define voltPin A0
#define sleepDisablePin D7
// resistor values for volt divider
// R1 = 11910;
// R2 = 3260;
// voltFactor = R2 / (R1 + R2);
float voltFactor = 0.212;
float voltage;
bool online;
unsigned long onlineTime;
unsigned long prevTime;
unsigned long time1;
unsigned int data[6];
unsigned int disco = 0;
byte buttonEnabled = 0;
byte sleepDisabled = 1;
byte sleepNow = 0;
byte restartChip = 0;
float cTemp = 0.0;
float fTemp = 0.0;
float humidity = 0.0;
pinMode(BUILTIN_LED, OUTPUT);
pinMode(sleepDisablePin, INPUT_PULLUP); // jumper for sleep override
for (int i = 0; i < 3; i++) // LED blinks to show booting
digitalWrite(BUILTIN_LED, 0);
delay(100);
digitalWrite(BUILTIN_LED, 1);
delay(100);
Wire.begin();
EEPROM.begin(512); // to store sleep state
// Serial.begin(9600);
voltFactor = 0.212; // for voltage divider
buttonEnabled = EEPROM.read(eepromAddress); // checks if it is in a sleep cycle
sleepDisabled = digitalRead(sleepDisablePin); // checks for sleep cycle bypass
if (sleepDisabled == 0) // stops sleep cycle if jumper LOW
sleepNow = 0;
buttonEnabled = 0;
Cayenne.virtualWrite(0, 0, "digital_sensor", "d"); // sends sleep cycle status to sleep button on dashboard
time1 = millis();
} // setup
if (millis() - time1 > 20000) // loop to get & send data every 20 seconds
getTemp();
execute();
if (online == true) // blinks LED if online about every 1 sec
digitalWrite(BUILTIN_LED, LOW);
delay(10);
digitalWrite(BUILTIN_LED, HIGH);
else
} // loop
void getTemp() // pulls temp & humidity via i2c per datasheet, gets voltage
Wire.beginTransmission(Address);
Wire.write(0x2C);
Wire.write(0x06);
Wire.endTransmission();
delay(500);
Wire.requestFrom(Address, 6); // get data
if (Wire.available() == 6)
data[0] = Wire.read();
data[1] = Wire.read();
data[2] = Wire.read();
data[3] = Wire.read();
data[4] = Wire.read();
data[5] = Wire.read();
cTemp = ((((data[0] * 256.0) + data[1]) * 175) / 65535.0) - 45;
fTemp = (cTemp * 1.8) + 32;
humidity = ((((data[3] * 256.0) + data[4]) * 100) / 65535.0);
voltage = (analogRead(voltPin) / 1024) * 3.3;
voltage = voltage / voltFactor;
} // getTemp
void execute()
time1 = millis(); // record transmit time
// temp, humidity, and batt voltage
Cayenne.virtualWrite(5, fTemp, "Fahrenheit", "f");
Cayenne.virtualWrite(6, humidity, "Percent", "p");
Cayenne.virtualWrite(8, fTemp, "analog_sensor", "null");
Cayenne.virtualWrite(9, humidity, "analog_sensor", "null");
Cayenne.virtualWrite(7, voltage, "analog_sensor", "null");
Cayenne.virtualWrite(10, voltage, "analog_sensor", "null");
// system info
Cayenne.virtualWrite(23, disco, "counter", "null");
int time2 = (millis() / 1000) / 60;
Cayenne.virtualWrite(24, time2, "counter", "null");
onlineTime = ((millis() - prevTime) / 1000) / 60;
Cayenne.virtualWrite(25, onlineTime, "counter", "null");
if (sleepNow == 1) // if sleep is active, chip sleeps after data transmit
ESP.deepSleep(1200000 * 1000); // sleeps for 20 min
} // execute
CAYENNE_CONNECTED()
online = true;
prevTime = millis();
if (buttonEnabled == 1) // checks if sleep cycle active
Cayenne.virtualWrite(0, 1, "digital_sensor", "d"); // sends value of sleep to dashboard
sleepNow = 1;
CAYENNE_DISCONNECTED()
online = false;
disco++; // record disconnect
CAYENNE_IN(0) // sleep button
sleepNow = getValue.asInt();
if (sleepNow == 1) // save sleep cycle status to eeprom to read after reboot
EEPROM.write(eepromAddress, 1);
EEPROM.commit();
else
EEPROM.write(eepromAddress, 0);
EEPROM.commit();
CAYENNE_IN(1) // trigger chip restart
restartChip = getValue.asInt();
delay(1500);
if (restartChip == 1)
Cayenne.virtualWrite(1, 0, "digital_sensor", "d"); // writes reboot button back low before restart
delay(1500);
ESP.restart();
