ive tried the steps that you gave, but hmm there is still error
can you share the first few line of the serial monitor when the arduino is restarted.
Hi there,
Can you please help me convert the sketch into mqtt?
Joseph
which sketch are you referring to? there is a sketch in MQTT already.
The one that tad.dvor published at the beginning of the post.
It’s called sensor.txt
it is very simple as replacing old cayenne code with new new cayenne code.
Steps:
1. Set the Cayenne authentication info to match the authentication info from the Dashboard.
2. Compile and upload the sketch.
3. A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
byte statusLed = 13;
byte sensorInterrupt = 0; // 0 = digital pin 2
byte sensorPin = 2;
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per
// litre/minute of flow.
float calibrationFactor = 4.5;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
// Set up the status LED line as an output
pinMode(statusLed, OUTPUT);
digitalWrite(statusLed, HIGH); // We have an active-low LED attached
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pulseCount = 0;
flowRate = 0.0;
flowMilliLitres = 0;
totalMilliLitres = 0;
oldTime = 0;
// The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
// Configured to trigger on a FALLING state change (transition from HIGH
// state to LOW state)
attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
if((millis() - oldTime) > 1000) // Only process counters once per second
// Disable the interrupt while calculating flow rate and sending the value to
// the host
detachInterrupt(sensorInterrupt);
// Because this loop may not complete in exactly 1 second intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output. We also apply the calibrationFactor to scale the output
// based on the number of pulses per second per units of measure (litres/minute in
// this case) coming from the sensor.
flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
// Note the time this processing pass was executed. Note that because we've
// disabled interrupts the millis() function won't actually be incrementing right
// at this point, but it will still return the value it was set to just before
// interrupts went away.
oldTime = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to millilitres.
flowMilliLitres = (flowRate / 60) * 1000;
// Add the millilitres passed in this second to the cumulative total
totalMilliLitres += flowMilliLitres;
unsigned int frac;
// Print the flow rate for this second in litres / minute
Serial.print("Flow rate: ");
Serial.print(int(flowRate)); // Print the integer part of the variable
Serial.print("."); // Print the decimal point
// Determine the fractional part. The 10 multiplier gives us 1 decimal place.
frac = (flowRate - int(flowRate)) * 10;
Serial.print(frac, DEC) ; // Print the fractional part of the variable
Serial.print("L/min");
// Print the number of litres flowed in this second
Serial.print(" Current Liquid Flowing: "); // Output separator
Serial.print(flowMilliLitres);
Serial.print("mL/Sec");
// Print the cumulative total of litres flowed since starting
Serial.print(" Output Liquid Quantity: "); // Output separator
Serial.print(totalMilliLitres);
Serial.println("mL");
// Reset the pulse counter so we can start incrementing again
pulseCount = 0;
// Enable the interrupt again now that we've finished sending output
Insterrupt Service Routine
void pulseCounter()
// Increment the pulse counter
pulseCount++;
CAYENNE_OUT(V0) //Flow rate:
Cayenne.virtualWrite(V0, flowRate);
CAYENNE_OUT(V1) //Current Liquid Flowing:
Cayenne.virtualWrite(V1, flowMilliLitres);
CAYENNE_OUT(V2) //Output Liquid Quantity:
Cayenne.virtualWrite(V2, totalMilliLitres);
I keep on getting an error message while trying to upload. Any idea?
what error are you getting? can you share the error you are getting.
This work with ESP8266 07?
I can not connect via WiFi? Its possible?
i did not understand what you mean by above.
Hey guys, I know kind of old post but it is on topic so I didn’t want to start another one, specifically I disagree with disabling the interrupts while sending the data. In this use case the PPM of the sensor is really inconsequential (4.5/second) but in my case it is 400Hz since I am using a high precision flow sensor. What is exactly the reason one must disable interrupts while sending the data to Cayenne?
Why not prioritize the sensor interrupt so that it continues to increment the counter even while data is being sent to Cayenne?
pinMode(3, INPUT_PULLDOWN);
attachInterrupt(digitalPinToInterrupt(3), pulse, RISING);
NVIC_SET_PRIORITY(IRQ_PORTA, 0);
This way not a single pulse will be missed and we would have high accuracy increment of the total volume of liquid passed through the sensor
~B
so does it work the way you want?
@shramik_salgaonkar well it does but the challenge is being able to tell if there’s any difference at all, with ESP8266 there’s no way that I know of to derive any kind of measure around what is optimal and what isn’t so my solution may be superior or inferior and I have no way to tell…
well, with interrupt the sensor will be priorities that is only change there is.
