Help me with multithreading
I am trying to use this code Can someone who is a better programmer make this multithread for me with up to 8 threads?
I cannot get more than 1 button to work when I press one it locks the pi/cayenne until that button/script/timer is done. I’d like to use this for pump controls and have multiple running at the same time but in different variations/seconds the pumps are on for each one. but not a single script because the times needed are different depending on soil moisture contents ( a whole other project ) so for now I just need this script turned into multithread and I’m tired of racking my brain trying and not getting it to work.
import cayenne.client
import time
MQTT_USERNAME = “xxx”
MQTT_PASSWORD = “xxx”
MQTT_CLIENT_ID = “xxx”
def on_message(message):
print ("message received: " + str(message))
if (message.channel == 7) and (message.value == “0”):execfile(“12.py”)
if (message.channel == 8) and (message.value == “0”):execfile(“20.py”)
if (message.channel == 9) and (message.value == “0”):execfile(“21.py”)
i=0
timestamp = 0
while True:
client.loop()
timestamp = time.time()
i = i+1
you can do something like:
    if (message.channel == 2) and (message.value == "0"):
        subprocess.Popen('python3 11.py', shell=True)
        print("done")
    if (message.channel == 3) and (message.value == "0"):
        subprocess.Popen('python3 12.py', shell=True)
        print("done")
@adam any other way?
now im getting this but it all looks good
client.loop()
IndentationError: expected an indented block
That looks right to me
finally got the indent thing figured out it was copying funny.
now I get this when I go to press the button on the dashbaord.
indent preformatted text by 4 spaces
File “but1.py”, line 15, in on_message
subprocess.Popen(‘python3 20.py’, shell=True)
NameError: global name ‘subprocess’ is not defined
add import subprocess
that worked. new problem is i have to turn the button off/on to get it run the script is there a command to make it relay back to the button or for the buttom to check which status or just auto change back to last status or something?
i did not get what you want.
so to get the button to work ( run the script ) I have to press it once for on ( run script) then a second time for off ( does nothing ) but then when i hit it a 3rd time for on it will run the script.
I tried to trigger “when press on turn button X off” but it did not always work just sometimes it would work and sometime it wouldnt trigger at all.
is there any way to add the button as a momentary button?
isnt a button suppose to work this way??
this is not the best way to trigger the button.
there is no momentary button.
