Iam trying to connect my arduino to cayenne using ESP 8266
i already have connected TX >> RX and RX >> TX
and managed to upload the code which is attached to the connection step
after uploading the code noting happens to the web page and it still waiting for connection
my code
[spoiler]
Steps:
- Install the ESP8266SerialLibrary.zip library via the Arduino IDE (Sketch->Include Library->Add .ZIP Library) from the Cayenne extras/libraries
folder (e.g. My Documents\Arduino\libraries\CayenneMQTT\extras\libraries) to compile this example. - Connect the ESP8266 as a shield to your Arduino. This example uses the Serial1 hardware serial pins available on the Mega. You can also try
using a software serial, though it may be less stable. - Set the Cayenne authentication info to match the authentication info from the Dashboard.
- Set the network name and password.
- Compile and upload the sketch.
- A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
char ssid = “-”;
char wifiPassword = “-”;
char username = “-------”;
char password = “-------”;
char clientID = “--------”;
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
} [/spoiler]
