Hi Shramik. At this moment not. The idea is that with a trigger from cayenne side, the coding to get the value is triggered and the value has to be returned to cayenne.
sorry, but i did not understand the above. before using the above code use this code Cayenne-MQTT-Python/Example-03-CayenneClient.py at master · myDevicesIoT/Cayenne-MQTT-Python · GitHub
Hi Shramik. I used example 4, but now I think I understand what went wrong. My development should work as follows: send a trigger from cayenne-side. In the python program this trigger causes an extra piece of program to be triggered. So when the trigger is send, a variable in my python is set to TRUE. when TRUE, the value is retrieved from the other api-call and returned to cayenne.
this trigger which you are referring is receiving data from cayenne when the button on the cayenne dashboard is changed?
but the command client.virtualWrite(2, 25, “lum”, “p”) is correct to send the value 25 to the channel 2 in my case?
yes indeed
to receive data or subscribe to button cmd topic you need to use this code Cayenne-MQTT-Python/Example-02-ReceiveData.py at master · myDevicesIoT/Cayenne-MQTT-Python · GitHub and then changing this part:
def on_message(message):
if (message.channel == 4) and (message.value == "1"):
//execute whatever you want
whereas the word referrs to Cayenne Docs
Yes, I had that already, but ran into the problem that i couldn’t process my program. to avoid this I copied my logic into the main program. now I can alter my local variable when the trigger is recieved. The only problem that I have now is that client.virtualWrite(2, 25, “lum”, “p”) does not show my value of 25 in the widget in cayenne. This statement is correct?
Do you know why the example 4 is used?
anyways you can try something like this:
#!/usr/bin/env python
import cayenne.client
import time
import logging
MQTT_USERNAME = ""
MQTT_PASSWORD = ""
MQTT_CLIENT_ID = ""
x = 0
global x
print("button is pressed")
x = 1
client.begin(MQTT_USERNAME, MQTT_PASSWORD, MQTT_CLIENT_ID, loglevel=logging.INFO)
i=0
timestamp = 0
while True:
client.loop()
client.celsiusWrite(1, i)
timestamp = time.time()
i = i+1
if x == 1:
#execute your code here
client.virtualWrite(6, x, "lux", "p")
x = 0
Hi. I will come back to you tomorrow. I’m now altering my code. Thnx so far
Hi Shramik. I managed to get it working. Thnx for your help. I’m now completing my code. Maybe I run into more problems, but then I will ask again.
Thnx for now.
