No trigger available for Thermistor?!
Hi Everyone,
Ive set up an aquarium IoT project. I have a pretty sophisticated inline heater in place that has lots of built in safeties. However, since I have a relay controlling its outlet, I wanted to add just a “watch dog” high limit safety in the event that the water temp reached an unsafe level, indicating a malfunction with the heater or its safeties.
I have a thermistor in place, giving me good data. But when I go to set up a trigger, it does not appear in my “IF” drop down. Is this a bug? Am I doing something wrong?
Have you added the correct data type for the widget?
You may try deleting the widget and let it re-add it automatically.
I integrated the sketch Cayenne produced when adding the widget with my my main code for the rest of the actuators which included the <Cayenne.Temperature.h>. It is just a generic 10k ohm thermistor, so in theory you dont need any special library as its just a true analog value being interpenetrated correct?
I have tried deleting and adding the same device as a generic analog input and also have had success with monitoring through the widget, but it still does not appear in my “IF” drop down. I am unaware it would re-add anything automatically though… could you explain that a little more please?
Here is my code if it helps
Thanks!
char username[] = "";
char password[] = "";
char clientID[] = "";
#define VIRTUAL_CHANNEL_1 V1
#define DIGITAL_PIN_12 12 //LIGHT
#define VIRTUAL_CHANNEL_2 V2
#define ACTUATOR_PIN_11 11 //AIR PUMP
#define VIRTUAL_CHANNEL_3 V3
#define ACTUATOR_PIN_10 10 //WAVE MAKERS
#define VIRTUAL_CHANNEL_4 V4
#define ACTUATOR_PIN_9 9 //HEATER
#define VIRTUAL_CHANNEL_5 V5
#define ACTUATOR_PIN_8 8 // FILTER & PUMP
#define VIRTUAL_CHANNEL_6 V6
#define SENSOR_PIN A5
const float resistance = 9780;
Thermistor thermistor(SENSOR_PIN, resistance);
  //Serial.begin(9600);
  pinMode(DIGITAL_PIN_12, OUTPUT);
  pinMode(ACTUATOR_PIN_11, OUTPUT);
  pinMode(ACTUATOR_PIN_10, OUTPUT);
  pinMode(ACTUATOR_PIN_9, OUTPUT);
  pinMode(ACTUATOR_PIN_8, OUTPUT);
CAYENNE_IN(VIRTUAL_CHANNEL_1)
  if (getValue.asInt() == 0) {
    digitalWrite(DIGITAL_PIN_12, HIGH);
  else {
    digitalWrite(DIGITAL_PIN_12, LOW);
  CAYENNE_IN(VIRTUAL_CHANNEL_2)
    digitalWrite(ACTUATOR_PIN_11, HIGH);
  else {
    digitalWrite(ACTUATOR_PIN_11, LOW);
CAYENNE_IN(VIRTUAL_CHANNEL_3)
    digitalWrite(ACTUATOR_PIN_10, HIGH);
  else {
    digitalWrite(ACTUATOR_PIN_10, LOW);
CAYENNE_IN(VIRTUAL_CHANNEL_4)
    digitalWrite(ACTUATOR_PIN_9, LOW); // LOGIC IS INVERTED FOR NC WIRING
  else {
    digitalWrite(ACTUATOR_PIN_9, HIGH);
CAYENNE_IN(VIRTUAL_CHANNEL_5)
    digitalWrite(ACTUATOR_PIN_8, LOW); // LOGIC IS INVERTED FOR NC WIRING
  else {
    digitalWrite(ACTUATOR_PIN_8, HIGH);
  CAYENNE_OUT(VIRTUAL_CHANNEL_6)
  //Cayenne.celsiusWrite(VIRTUAL_CHANNEL, thermistor.getCelsius());
  // To send the temperature in Fahrenheit or Kelvin use the corresponding code below.
  Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL_6, thermistor.getFahrenheit());
  //Cayenne.kelvinWrite(VIRTUAL_CHANNEL, thermistor.getKelvin());
can you try changing V1 to 1 in:
and also for other virtual channels.
Delete the temperature widget from the dashboard. Once you upload the code successfully, Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL_6, thermistor.getFahrenheit()); will create a green temporary widget on your dashboard with channel 6. Click on the + to make it permanent.
