Arduino Code:
char username[] = "8fd42ce0-bec2-11e8-bf81-6b1a7e6fd7d2";
char password[] = "942fbf9ab708d9f343cad4dfd35490e84ab90152";
char clientID[] = "4c5d3420-c5b1-11e8-9f7b-1d1cb94fd98c";
// Mac address should be different for each device in your LAN
byte arduino_mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
IPAddress arduino_ip(192, 168, 0, 23);
IPAddress dns_ip(8, 8, 8, 8);
IPAddress gateway_ip(192,168, 0, 11);
IPAddress subnet_mask(255, 255, 255, 0);
Cayenne.begin(username, password, clientID, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
CAYENNE_OUT_DEFAULT()
CAYENNE_IN_DEFAULT()
Error Message after upload:
In file included from C:\Users\mauri\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTEthernetClient.h:21:0,
from C:\Users\mauri\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTEthernet.h:25,
from C:\Users\mauri\Documents\Arduino\Ethernet_Cayenne\sketch_sep24a\sketch_sep24a.ino:4:
C:\Users\mauri\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h: In member function 'void CayenneArduinoMQTTClient::connect()':
C:\Users\mauri\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:58:63: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
Serial Output:
[560] IP: 192.168.0.23
[561] Connecting to mqtt.mydevices.com:1883
[2388] Network connect failed
[5213] Network connect failed
[8038] Network connect failed
[10862] Network connect failed
[13687] Network connect failed
[16513] Network connect failed
[19337] Network connect failed
